SOURCE: Elna 2002 Sewing Machine
Can't get a manual for you but here's how to wind a bobbin.
Guide your thread from the spool holder to the bobbin thread tension device on the top left side of the machine.(That's the round assembly that is about 1/2 inch in diameter with a screw in the center of it.) Pull the thread in the front and wrap it to the back and continue towards the bobbin winder on the right side top. Wrap thread around the bobbin, place the bobbin on the spindle sticking up. Release the handwheel(either by pulling out on the center of the wheel or twisting on the center of the wheel). Press on the foot control. It should stop winding when it is full.
To thread the machine
all machines thread the same. TTN tension, take up,
needle.
Beginning with the spool, guide the
thread through the thread guides to the tension assembly. Pull the thread
through the tension assembly and test it to make sure the tension is working
correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or
something in the middle. Raise the presser foot and pull the thread through the
tension. It should pull easily!! Lower the presser foot and pull the thread. It
should pull noticeably harder.) If it passes this test, continue up through the
take up lever,then down through the thread guides to the needle. Make sure your
needle is fully inserted and turned the correct way. Flat side to the back and it threads front to back
Sewman7
SOURCE: Manual to Elna Lock Pro5dc computer sewing machine
i hope this link will be useful for u to download the manual
but u need to select the model no
http://safemanuals.com/brand-user-guide-instructions-owner-manual/ELNA
SOURCE: service manual elna 722010 sewing machine
www.whitesewingcenter.com has the manual for an Elna 722010.
SOURCE: My elna sewing machine bobbin
If the fly wheel is going around then the clutch isn't disengaged to wind the bobbin, you need to pull out the flywheel on your model to disengage the clutch for bobbin winding.
Take thread from thread spool across to bobbin winder thread guide, then back to bobbin and thread the tail through the hole on top of the bobbin. Place bobbin onto spindle on top of machine and then push it against the stop to engage the bobbin winding motor. HOld the thread tail up and start winding slowly until the bobbin core has been covered including the starting point. Stop and trim off the thread tail with scissors. COntinue winding bobbin and give the thread a nudge if needed to wind evening top middle and bottom of the bobbin. A good smooth wind is important. Also don't wind at full speed and keep an eye on the thread reel that the thread is coming off, you don't want it bouncing around as this will **** the thread and stretch then relax it affecting your bobbin wind.
Obviously if you know this and the bobbin winding mechanisim is just not working, then it will need a service/replacement by an Elna repair person.
Hi alan wade, I want to help you with your question, but I need more information from you. Can you please add a description of your model in the comment box? Is it a Star Series, blue top, white body made by Tavaro?
