Question about Siemens Ovens
My Siemens double oven is reading unlocking door. How do I get it to unlock? It is model #hb30d50u
Anonymous
SOURCE:
reg501
Richard
  • 413 Answers
SOURCE: cant unlock self clean oven door
Door lock motor has probably failed.....Self clean on many ovens can be a self destruct mode. Door latch motors, sensor probes and even the electronic controls can be destroyed by this operation. Suggest oven cleaner method.
Posted on May 29, 2008
Anonymous
SOURCE: oven door lock
Hold oven door light in while touching clean cycle enter up arrow or down arrow then hit cancel. door will unlock.
Posted on Nov 18, 2008
Anonymous
SOURCE: whirlpool rbd275pdb double wall oven died during self clean
The first time we used our Whirlpool oven the same thing happened - no power and yet the circuit breaker was not blown. I called Whirlpool, and they sent out a technician to check it out as it was still under warranty. He said the temperature was off (too hot) by 20F - he adjusted. He also replaced the blower. What he did not tell me was that the thermal fuse had blown, and he replaced it - this was the REAL cause for the failure. I got the impression that he did not want to let me in on the secret. He did not note on the paperwork that he replaced the thermal fuse. Last week I decided to run the oven through the self-cleaning cycle (the oven is now 8-1/2 yrs old) - I don't believe that we cleaned the oven but a couple of times since the first time that it was "repaired." I used the default 3-1/2 hour setting. Everything appeared to be fine - the oven went through the cleaning cycle with no apparent problems. The display now read "cool down" - I went to bed thinking everything was okay. I got up the next morning only to find out that the power was out. I called Whirlpool and demanded that they repair the unit again as they clearly never fixed it correctly in the first place. They offered me 15% off on a new oven - WHOOPEE! I asked to speak with the supervisor - he did not budge either. I was upset, and I told him that I would NEVER purchase a Whirlpool appliance again! I decided to tear into the oven to see if I could detect anything wrong. I pulled out the front panel - everything looked okay. I then noticed the "thermal fuse" - I did not know what it was called at the time, but it looked familiar. I checked voltage on either side of the fuse and found the voltage to be zero on the downstream side of the fuse. I pulled it out and read the information on the device: Microtemp 110C. I called a local appliance repair shop - they told me that it would cost $50 to purchase a new fuse! I told them that seemed very high. I ended up stopping at Radio Shack. They have thermal fuses in various temperature and voltage ranges. I got a 144C 10A fuse and carefully soldered the connectors to it and replaced the protective plastic sleeve. I actually bypassed the thermal fuse in order to use the oven before I found the replacement fuse. While it is a good idea to have a protection device for the slim chance that an oven may malfunction by overheating, it is not a necessity for the functionality of the oven. Hopefully, the thermal fuse will not fail during my next attempt to self-clean the oven. I do have a concern about the 10 amp rating, but I'm sure that it will work fine.
Posted on Apr 15, 2009
Anonymous
SOURCE: oven door won't unlock
kenmore selfcleaning oven door will not unlock code f9 appears in window
Posted on Apr 16, 2010
The oven door won't unlock even though self-cleaning has been cancelled
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Aug 10, 2011 | Frigidaire FEB27T5D Electric Double Oven
Used the self cleaning cycle 24 hrs. ago, but the oven door will not unlock. We tried to run it through another clean cycle but we recieve an E1 error.
Sorry to read about your problem, I hope this helps you out.
you may have done a panel lock, so try the first solution.
To Lock/Unlock Control: Before locking, make sure the ovens, Timer and Timed Cooking are off. Press and hold START/ENTER until a single tone sounds and "Loc," a picture of a lock and "START?" will appear on the oven display, about 5 seconds. Repeat to unlock and remove "Loc" from display.
To Stop Self-Clean any time:
Press UPPER OFF, LOWER OFF or OFF/CANCEL. If the oven temperature is too high, the door will remain locked. It will not unlock until the oven cools.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
Dec 25, 2010 | Whirlpool RBD245PDS Electric Double Oven
I set the upper oven to clean and it did clean but now the door won't open and the message reads too hot, door locked. How do I open the door?
heatman101
Sep 17, 2010 | KitchenAid KEBC247 Electric Double Oven
I did the self clean on the upper oven. When the stopped cleaning it cooled down, but the door will not open. (Unlock)
heatman101
Sep 15, 2010 | Viking VEDO205 Electric Double Oven
GE Oven door won't unlock after cleaning cycle (and cool down).
Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
Also check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Apr 24, 2010 | GE JKP45 Electric Double Oven
Unlock double oven
the unit should unlock by itself after it has cooled down if not try and hold the clear off key for 3-5 seconds pushing in o nthe door at the same time sshould unlock them
Apr 13, 2010 | Frigidaire 30 in. Electric Gallery Series...
Self cleaned oven for first time. when through
heatman101
llhj
Jul 14, 2009 | DCS (WOTD-227) Double Oven
GE Electric Double Oven Door Will Not Unlock
heatman101
Nov 05, 2008 | GE Profile JTP56 Electric Double Oven
Ge double oven
I believe this is because it takes a while for your oven to cool down (the cleaning cycle uses a very high temperature to burn up the grease and food). The timer is how long it takes before it will be cool, at which time the oven will unlock.
Mar 17, 2008 | GE Monogram ZET3058SHSS Stainless Steel...
Kenmore double oven f4 fault code - door locked.
We had the F4 problem and called Sears repa. They sent someone out. The guy opened the panel above the bottom oven (we have a double oven) and hit a reset button - then charged us $75. This has worked on several occasions (my husband did it after that). But then that didn't work and Sear's told us it was the electronic panel which they replaced twice. Now it's (F4) happened again on the top oven only on a brand new electronic panel. So I guess it's the heat sensor this time.
Dec 31, 2007 | Ovens
Ovens Logo
67 people viewed this question
Top Siemens Ovens Experts
Tom Chichester
Marvin
Marvin
David Spradling
David Spradling
Are you a Siemens Oven Expert? Answer questions, earn points and help others
