Sounds like there is a blockage in the fuel line that lets gas through for a short period of time, then becomes very low and the engine stalls. Look for dirt in the lines and clean out.
Make sure the fuel tank vent is open - squeeze bulb to prime and try with fuel tank cap off to check if venting is a problem - if neither work then time to remove carburetor and clean with high pressure air.
Symptoms are "fuel starvation" enough fuel to idle but not enough to run at higher fuel consumption rates. https://www.6ya.com/callphilipforhelp
SOURCE: 1999 volkswagen stalled
first check cylinder 1 , spark plug, ht leads, coil,
then clean the trottle body with carb cleaner
if that does not work replace the throttle body, comes complete, and do a basic setting on it with diagnostic machine
SOURCE: Car stalls when oil pressure drops...20 minutes to restart
No it is a fail safe. When your oil pressure drops below (on most cars) 30 psi your computer will shut your fuel pump down until you either let it sit for a while and it resets or until oil pressure builds again. Sorry!
SOURCE: my 2005 town and country stalls after fillup..any ideas?
every vehicle should have one. trace your fuel line. could also be some water in your gas tank. put in some isopropol alcohol / gas line antifreeze to dissapate water.
SOURCE: windstar van stalls while driving
Inspect Carburetor Dirty and Improperly Functioning Carburetor. Inspect Carburetor Incorrect Carburetor Adjustment. Inspect Carburetor Worn, Faulty or Damaged Carburetor. Inspect EGR Valve EGR Valve Sticking Open/Leaking. Inspect Idle Air Control Valve IAC Valve Sticking or Faulty. Inspect Mass Air Flow Sensor Damaged, Loose, or Faulty Mass Air Flow Sensor or Circuit Inspect FreshAir Intake Hose Clogged or Damaged FreshAir Intake Hose. Inspect Throttle Position Sensor Faulty or Incorrectly Connected Throttle Position Sensor. Inspect Fuel Filter Clogged or Dirty Fuel Filter. Inspect Fuel Injector Dirty or Worn Fuel Injectors.
