Question about Electrolux Kitchen Ranges
My electrolux icon dual fuel range quit working. The fan continues to run and the bake light and rack light stay lit up.
6ya staff
SOURCE:
Anonymous
SOURCE: Electrolux Icon Mystery issue
Check to be sure your racks are all slid in to the back. Are you getting a error code?
Posted on Dec 25, 2007
aborcass
Ron Coons
  • 2651 Answers
SOURCE: Electrolux dual range has a
its electricall disconnected nad your still getting a high pitched sound???? that would only leave your gas connection as the culprit
Posted on Mar 22, 2008
Anonymous
  • 750 Answers
SOURCE: electrolux built in wall oven,
Hello stevefer
Welcome.
You said, Your Electrolux built in wall oven, lights and digital display work fine, fan works fine, but the oven will not heat regardless of the mode (broil, bake, convention roast, convection bake)
First,
1.What is the Model Number and the year of your wall oven?
2.Did the oven light up and display with any error codes?
3. Did you try to turn the breaker off for 5 minutes to see if this will reset the system?
Perhaps the heating element is failing and may need to be replaced.
I will be able to better assist you when you reply with this information.
Waiting your response.
Huuum
Posted on Oct 16, 2008
crookedrn
SOURCE: Electrolux Icon Oven won't self clean - "Remove Racks" displayed
I was getting the remove rack error until I finally figured out what it wanted me to remove. When you say you removed the rack supports, do you mean just the sliding parts or the whole side metal rack support? At first I thought they were bolted in, but I read somewhere that they come out, too. Upon further investigation, I found the rack supports just slide into the side walls at 4 points. I had to use a little force to pull them out, but they came out and my oven is self-cleaning as I write this. I just thought I would share in case you or others haven't figured it out yet. Now I will just have to see how hard it is to get them back in...
Posted on Feb 21, 2009
cjfmc
  • 39 Answers
SOURCE: electrolux icon dual-fuel range installation problems
its a bad EOC .Electronic Oven Control....You need to replace the board
Posted on May 22, 2009
Blue lights flashing can not get to reset
Hey Troy, I understand that you are having problems with your Electrolux Dual-fuel Range. Have you recently installed the range or had a power outage? When the range is first plugged in, or when the power supply to the range has been interrupted, the indicator lights will flash and the control will beep. To stop the lights from flashing, turn the selector control knob to BAKE and back to OFF. You can also attempt a hard reset by unplugging or turning the household power breaker off to the appliance for five to ten minutes. If the problem persists, please reach out to a professional technician. Hope this helps! -JK
Oct 26, 2015 | Electrolux Icon E30df74gps 30" Pro-style...
After a power outage. All the lights on the range are blinking/flashing, how do I turn them off? Everything still works. Just can't turn off lights.
Hey Scott, I understand that you are having problems with your Electrolux Dual-fuel Range. When the range is first plugged in, or when the power supply to the range has been interrupted, the indicator lights will flash and the control will beep. To stop the lights from flashing, turn the selector control knob to BAKE and back to OFF. You can also attempt a hard reset by unplugging or turning the household power breaker off to the appliance for five to ten minutes. If the problem persists, please reach out to a professional technician. Hope this helps! -JK
Oct 18, 2015 | Electrolux Icon E30df74gps 30" Pro-style...
Electrolux dual fuel range 316471210 self clean remove racks message displayed and cannot proceed
Hi friend, thank you for your inquiry!
I understand that you are receiving a "remove racks" message on your Electrolux range. The oven racks and supports must be removed before the self-clean will initiate or the control will not allow the self-clean to turn on. I hope this is helpful. -Matt
Sep 04, 2014 | Electrolux Kitchen Ranges
Electrolux icon duel fuel range racks red light wont stop flashing even though I removed all racks, so oven will not start self clean cycle
Good Morning Andrea,
I see that you are having trouble with your Electrolux range, model# E30DF74GPS, and getting it to go into the self-clean cycle. I would suggest giving it a hard reset. First make sure the racks are in. Next, cut the power at the circuit breaker and leave it off for 2-3 minutes. After the time has elapsed cut the power back on. Start the self-clean cycle with the racks inside the oven. We're trying to get the oven to recognize the racks are inside. Once it states the racks are in, cancel out and take the racks out. Now, with the racks out start the self-clean cycle again. If you are still receiving the red light blinking, I suggest contacting the manufacturer or your local authorized technician. Hope this has been helpful.
-Best Regards-
WP
Mar 23, 2014 | Electrolux Icon E30df74gps 30" Pro-style...
Locked Oven Door
You mention shutting off the power. Did you use you circuit breaker to turn off the oven. If not, you should try shutting off power using the circuit breaker. Turn off breaker, wait at least a few minutes, then turn breaker back on. This may reset the oven
Dec 25, 2013 | Electrolux Icon E36DF76GPS Dual Fuel Range...
Our larger oven will not turn on and the led lights do not work either. the smaller oven does turn and led lights work. All burners work fine any ideas??
Hello Brian, thank you for allowing me to assist you!
I understand the larger oven of your Electrolux range is inoperable. Let's try resetting your range by either unplugging it or flipping off the breaker for about ten minutes. An experienced service technician may need to further evaluate this issue if it was not resolved with the power reset. In this case, your appliance may possibly be experiencing a communication properly with the EOC (electronic oven control), faulty bake/broil element, or a potential wiring failure.
Dec 16, 2013 | Electrolux E48DF76EPS Dual Fuel Range
Ignitor won't shut off
The Viking manual says that an ignitor that continues to try to light even after the burner has been lit indicates improper grounding, and that an electrician should be consulted.
Perhaps you could try to replace the ignitor, and see if that fixes the problem?
I have a similar age, 6-burner 36" rangetop.
Sep 30, 2008 | Viking 48" 6 Burner, Grill Professional...
Dec 14, 2007 | Electrolux ICON Designer E30SO75ESS Oven
Electrolux icon dual-fuel range installation problems
Dec 06, 2007 | Ovens
Kitchen Ranges Logo
89 people viewed this question
Top Electrolux Kitchen Ranges Experts
Marvin
Marvin
Eric Rotmil
Eric Rotmil
Mike Henne
Level 1 Expert
Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
