Boating Logo
Tom Rolfe Posted on Jun 10, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
First time user I can not get the air to fill the pontoons??
SSN-MM3
Level 2:
Sergeant:
  • Expert 272 Answers
  • Posted on Jun 10, 2019
SSN-MM3
Expert
Level 2:
Sergeant:
Answers
272
Questions
0
Helped
80186
Points
947
Try it a second time
1 Related Answer
Anonymous
  • Posted on Jul 14, 2012
SOURCE: 2005 Water Skeeter Pontoon..What kind of pump for the valves
If you look up Halkey-roberts valves you will see the air filler part.
First time out this year yamaha2005 115 4stroke new gas new filters cranks and runs great up to 15mph on pontoon boat but bogs if you give it any more gas
I have a 2007 Yamaha 115hp 2-stroke on my pontoon. They are a dependable engine. The first thing I would check is for a tiny pinhole or crack in a fuel line, that would cause it to "suck air" into the line at high power demand situations. If the lines are good, check the plug wires. Make sure they are firmly attached to the plug, and insure that they don't have a worn spot, anywhere along the wire that could be shorting out to the engine block or casing. Also, the air filter may be wet or oily, reducing air flow. If none of those solve the issue, it may be a coil pack, and might need to visit the dealer for diagnostics.
Feb 12, 2017 • Boating
What is the foam in Pedal Boats?
when a pedal boat has foam it means that the pontoons are filled completely with no air voids. This construction is considered to be the safest and the best for pedal boats.
Jan 17, 2013 • Boating
2answers
Assembly of a Cimarron Pontoon Boat
have a similar boat, but it's been a year or so since I used it. Here's what I remember.
Lay it all out first. It's very confusing until you get a visual. The seat rests on two bars. These bars span the two pontoons. I believe they use pins, rather than bolts to secure it. You probably have a basket and maybe a trolling motor mount. Get rid of the mount, unless you plan on using it. If you do, it attaches to the rear basket. The basket mounts to the back of the chair and rear bar with bolts.
Next, the leg holders slide in and there should be pins to hold them in place for the right distance. If there is a stand up plate and a casting bar, you're on your own on how to attach them. Obviously they go in the front, but I have no idea how they are attached.
Mine had an anchor, but this was a huge hassle. Much easier to pull to shore than park in the water.
There is probably a mesh type piece that fits under or around your seat with bungies or hooks. It may have a fish measure on it. If it does, that goes to the front.
The oars are merely pinned in at a comfortable spots. There should be oar "stops," that slide over your oars. Again, you have to adjust the length to how long your arms are. They don't slide too easily. And, they are needed so your oars don't slide off into the water.
The side bars should have a hump to rest the pontoons on. Buy a double pump and save some time, (or an electric pump). The following is the most important fact of all, You have two bladders in each pontoon. Inflate them BOTH. Air up one from the front, then the other from the rear, back and forth until the pontoon is ready to burst. This prevents a disaster. If one deflates or is punctured, the other one has enough air to support you to shore. Strap them on and you're ready to go. And I would suggest a practice run in calm water first. They are a little awkward at first. Good luck
Assembeling the Cimerron Pontoon Boat
I have a similar boat, but it's been a year or so since I used it. Here's what I remember.
1helpful
I need a new inflation valve for my colorado pontoon boat
Check E-bay -
Item number: 310151809453, Pontoon Boat Boats Outdoor Parts Repair Kit Kits black
What is your problems with pontoon bladder
Thanks for reply
Top Boating Experts
ADMIN Andrew
ADMIN Andrew
jws1013
Kardoc
Are you a Boating Expert? Answer questions, earn points and help others
