SOURCE: LG 37LC7D remote doesn't work
I heard that Best Buy is still selling these models despite this known problem- I am trying to have mione fixed but was told the replacement part is on back order until DECEMBER!
SOURCE: direct tv remote- volume control
Here is how you fix it:
http://www.dbstalk.com/showthread.php?t=116241&highlight=SAMSUNG+REMOTE
SOURCE: only vizio light come on then nothing. have to unplug to turn off
there a problem on power side.. chage the ic and the resistor going to ic and check also the signal diode.
SOURCE: Remote control has stopped working.
your remote needs to be put back in TV mode. press the tv button or slide the switch to tv
SOURCE: Panasonic remote and volume/channel buttons do not work
My son put a penny in the SD card slot of my Pansonic flat screen tv. I finally got the penny out but now the volume and tv controls do not work. I can change the channels through my cable box but that is it. The volume does not work on my cable remote or the flatscreen. What do you suggest I do to fix this problem?? Thanks, Josh
505, 506, 516, 523, 526, 566,
573, 612, 627, 647, 652, 653,
654, 655, 656, 658, 659, 664,
665, 667, 669, 670, 679, 680,
704, 717, 730, 738
Try each of the above codes in turn until you find the one which works best, i.e. controls most functions. This may be limited to contolling the power, volume and channel functions. I have also pasted the programming instructions for your remote below, in case you need them.
Regards,
BElectric.
NOTE: Before you start, locate the remote codes for the TV and write them down.
Follow these steps to program your remote control to work with your TV:
