Question about Amana Heating & Cooling
How do I get the fan to run for amana air conditioner model aufcu01d
  • 1,360 Answers
There should be a fan symbol on your remote control. In the "mode" control, there should be the following options.. Heat, cool, Auto and fan. If you select fan, only the fan will run. No heating or cooling.
Posted on Jun 10, 2019
6ya staff
SOURCE:
Techsim
James
  • 59 Answers
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Posted on Nov 02, 2008
Anonymous
SOURCE: fan not blowing
you need a 6.3v capacitor to get the fan going i had the same problem.
Posted on May 08, 2009
Anonymous
  • 614 Answers
SOURCE: Noisy Amana Quiet Zone air conditioner
The compressor sounds like the springs inside are bad. You can live with this are get the compresor eplaced if it is over five years old buy a new unit. Compressor will cost more than a new unit. Russ
Posted on Jul 19, 2009
Anonymous
  • 5 Answers
SOURCE: i have an amana portable electronic air conditioner wont turn on
try draining the water. Mine did the same thing. Started right back up. There is alot of water be careful.
Posted on Aug 03, 2009
Neil Vivian
  • 4 Answers
SOURCE: Amana AP148D-RB, Air Conditioner Parts
Not sure if you have fixed yet, but I had the same problem on my AP148D. There are 2 fans, 1 for the condenser (base of unit) and 1 for the evaporator (top of unit). My condenser fan disintigrated. Go to his web site and you will find a parts list for this model, and a distributer list http://service.haieramerica.com/Models.aspx?CID=231
Call this number and they have the parts in stock : 800-313-8495, mine shipped overnight. The parts are :
AC-8000-27 Wheel-blower condenser $21.81
AC-8000-26 Wheel-blower evaporator $21.81
I suspect you will need the first part. Hope this helps. Be careful to note where all the screws come from when dismantling !!!!
Posted on Jan 13, 2011
How do I replace the fan?
Free Amana Air Conditioner User Manuals ' ManualsOnline ...
homeappliance.manualsonline.com > ... > Household Appliance Amana
Products 1 - 10 of 10 - Amana Air Conditioner 18M23TB. Amana Room Air Conditioner Use And Care Manual. Pages: 0 Saves: 0. See Prices Buy or Upgrade .
Jul 10, 2015 | Amana Portable Air Conditioner
I have the Amana portable 3 in 1 air conditioner model #ap077r. It works fine but air only comes out of the right half of the fan vent. Is this how it is supposed to be and if not, how can I fix it?
It probably has 2 evaporator fans and one has failed. (I couldn't find your model on the Amana site, so I don't have any additional information.)
Jun 20, 2014 | Heating & Cooling
I have an amana 90 home air conditioner w/ a amana prestige compressor. compessor runs but cooling fan not turning ,fan is not locked up and unit has power .of course w/fan not turning home is not...
Could be a couple of reasons for this:
1. Condensor fan motor bad.
2. Condensor fan motor loss of power.
3. Condensor fan motor capictor bad.
Unit has control for fan for low ambient operation and unit is low on freon telling fan its cold out side and dont run.
Hope this helps. wally
Jul 22, 2011 | Amana Heating & Cooling
I have a 1400 btu portable air conditioner ( AMANA ) and the fan is broken, how to replace it.
Obviously, you will have to disassemble part of the cabinet to access the fan blade. Removig the blade should not be difficult. If it's the fan motor, than that may be a challenge. However, since you did not furnish the Model Number of your AC Unit, there's not much more I can tell you, other than where to find the part(s) you'll need. Try Factory Appliance Parts http://www.appliancefactoryparts.com/airconditioners/amana/amana-motors-and-blades.html You'll definitely need the correct Model Number of your unit, to search for the part(s) you'll need.
Hope this helped you.
Jun 27, 2011 | Amana Portable Air Conditioner
On the Amana comfort zone air conditioner, there is a switch that says exhaust closed. Do I want the exhaust open or closed when i have the cool on the air conditioner
Hi, when you are running it in the cooling mode, leave the exhaust open to remove the condenser hot air. If you want to run just the fan to circulate the air you can close it.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Aug 26, 2010 | Amana Comfort Zone 12M32PBEH Air...
Run fan continuous
Turn "off" the "energy saver" feature....
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
https://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Jul 18, 2010 | Amana DigiSmart PTH153B35AM...
I have an amana air conditioner (ace245e). It
seems like the control board is bad,
if you have experience with electricity you can test the fan & compressor bi-pass the power from the board to the compressor terminal, if the compressor run you know for sure the board is bad
Sep 18, 2009 | Amana ACE245E Thru-Wall/Window Air...
Blower motor not blowing
you will have to replace the blower motor
Aug 11, 2009 | Amana PTH123B35AE Air Conditioner
Heating & Cooling Logo
27 people viewed this question
Top Amana Heating & Cooling Experts
Donni Steen
Bill Long
WatsHVAC
Level 1 Expert
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
