SOURCE: Poulan Riding Mower will run in neutral, not in forward or revers
you have safty switch on the mower one or more are bad there are three of them
win you put in reverse some mower will cut off this is a safty device on some mower
SOURCE: How do you remove the electric clutch from a
Remove the primary belt and mowing deck to give yourself some room to work.
Locate the wires from the clutch and follow them toward the frame until you find the plug and unplug it.
Remove the bolt and washer from the center of the clutch going up into the engine crankshaft and slide it off the shaft. It is quite heavy so be careful when it comes free.
SOURCE: Mower starts, but when I let off clutch, it dies.
when the seat goes out of adjustment due to the crappy adjustment bolt design, the bolt inadvertantly engages the safety switch under the seat.
SOURCE: husqvarna riding mower blowing white smoke out front
check the oil does it smell like gas the needle valve is not seating and gas over flows the carb and dumps it into the crank case
SOURCE: Husqvarna YTH 2448 shuts off when I let out clutch or engagae mower blades
Hi, check or replace the switch on the seat, basically its not telling the safety system that you are on the seat. Regards Phil.
