SOURCE: Fabric softener doesn't dispense
Fabric softener dispensers are notorious for getting all gummed up and clogged. Remove the dispenser cup and soak in some hot water to dissolve all residue. While you have the dispenser removed check under the dispenser cap in the agitator for gummy residue as well. Clean with hot water. There should also be an agitator seal cap under the dispenser. Make sure the cap and rubber o-ring are seated properly. Last of all, if the dispenser has a cone shaped cup inside, make sure it is inserted cone-side UP. The cup is designed to allow fabric softener to roll down the sides of it, NOT hold it. I hope this helps.
SOURCE: Maytag washer fabric softener dispenser is yucky
There is a 1/4" machine screw in a recessed hole close to the bottom of the agitator. Remove screw. Lift agitator off agitate shaft.
SOURCE: Speed Queen Top Loader heavy duty washer
First unplug the machine, now take off the front panel, two screws at the bottom of the front panel, front panel swings up and off.
check to make sure the six springs are still in place.
Under the tub is bearing housing between the tub and base usually white in color, under this is a plastic ring, does it seem to float easily when you move the tub. it could be broken. Also look around for loose or missing screws.
If all seems fine, make sure you have all four rubber feet on, level machine, in the front first side to side, then pull machine toward you to bring rear legs off floor, these are self leveling, have someone assist and make sure they are not stuck, use a pliers and break loose if they are. So with the machine on its front feet and the back feet off the ground set the machine down on all four feet check level front to back adjust as needed on the front legs. You should reset rear legs as you adjust the front. now with machine level tight the nut between the front legs and the base locking them.
This should help, if machine still shakes it could be the balance ring, has lost if solution its filled with a salt water solution, the hard part is you need to find it under the tub cover. we will go into the detail if we need to. ask more questions later
SOURCE: Draining water from inside through center.
The tub seal kit is $85 USD, You will also need a drive bell kit$23 USD, you should replace the upper bearing $?, for a complete rebuilt I would also replace the brake pads all three, and the belt, maybe the pump if it doesnt come off easily. Plus what you break taking it apart, so we are looking @ least $150.
Yes you can do it yourself, you dont need the tub wrench if you can borrow a deep socket, its the drive bell seal tool you really need.
Please let me know if you have additional questions. the serial number will tell you the age first two digits are year next two are month, starts with and R, built in Ripon WI.
