SOURCE: vacuum hose replace electrolux how to
YOU DON'T SAY IF YOU HAVE THE NEWER HOSE OR THE CLASSIC ONE WITH THE STEEL TIP (BETTER DESIGN). IF IT'S THE LATTER UN-SCREW THE SCREW CLOSEST TO THE STEEL TIP,TAKE A SMALL SCREW DRIVER AND LIFT THE THE PIECE OF PLASTIC THAT WAS SCREWED DOWN JUST ENOUGH TO SLIP THE HOSE OUT.
WHAT YOU'LL BE FACED WITH IS SOMETHING I WOULDN'T SUGGEST CUTTING.
IT MAY BE MORE PRACTICAL BUYING A NEW HOSE. AN ELECTROLUX WILL LAST FOREVER,BUT YOU DO HAVE TO REPLACE THINGS LIKE THE COMBO DUST/UPHULSTRY ATTACHMENT. THE HOSE IS PROBABLY THE FIRST THING YOU WOULD NEED TO REPLACE BECAUSE OF AIR LEAKS. I'VE HAD MY OLYMPIA ONE FOR 27 YEARS AND HAD TO REPLACE THE HOSE ABOUT 10 YEARS AGO. YOUR CHOICE.
SOURCE: Electrolux Epic 6500SR Full Bag sensor working, Does not Reset properly
The problem was a sticking switch that was not being reset. The vacuum on/off switch mechanism is comprised of two switches. One is the main switch that turns the vacuum on and off. The second is a shut off switch that gets tripped when the full bag sensor is engaged. This second switch is supposed to get reset when you push the on/off switch on the outside of the machine. The full bag shutoff switch was stiff and it, therefore, was taking a couple of presses of the on/off switch to move the shutoff switch back into the running position.
SOURCE: electrolux Epic 6500 SR series
Ok i found a solution for my Electrolux Epic 6000 which had the exact same symptoms as you describe. I fixed it by disabling the "bag full sensitivity adjustor" (BFSA for short, for the lack of a better term). For that i opened the case, removed the hose that was preventing me from opening complety the casing, unscrewed the transaparent BFSA mechanism.
Here's the walkthrough:
- Open the case: Open the top part of the vacuum (where the bag is)
- Remove the 2 side rubber by sliding them from the back to the front of the vaccuum
- Remove the "plastic cap" at the end of the vacuum (you can slightly lift the vacuum top part to make it easier)
- Now unplug a small air hose to be able to open the case completely.
- Find the BFSA device and unscrew it.
- Now give your vacuum a try... it worked for me.
SOURCE: Electrolux Renaissance power nozzle turning on and off, brass pins hot
The deal with the Renny is that it runs off of circuit boards. Usually the problem of the main motor shutting on and off is caused by one of the Triac boards located inside the canister. Another problem could be the thermostat wire located on the inside of your motor itself. It's almost never the thermostat, so the triac board is most likely the issue.
As far as your power nozzle goes, the head eminating from the swivel body is in most cases due to an older design of the power nozzle. I would suggest investing in a new elbow assembly that includes a new swivel body as well as newer style of wiring that is proved to reduce arcing and heat production within the power nozzle.
In some cases, fixing the power nozzle will fix the problems you are experienceing with the main motor as the arcing happening in the power nozzle can in fact turn off your machine. So investing in a new elbow assembly for your power nozzle could in fact solve the problem in its entirety.
SOURCE: Electrolux Vacuum keeps turning off and light looks like bag with
Turn the knob on the top of the vacuum all the way to the right.I had the same problem and that fixed it.
