It would be helpful if you posted the model number. There are several types of connections. Some are threaded and usually use a gas-compatible thread sealant compound or thread tape (be certain the sealant is specified for natural gas or propane!).
Some are simply flared friction fittings, possibly with an internal gasket ring. Inspect the gasket if any, and if it is in good condition, just push it back together. If the metal is worn, corroded or cracked, replace the part.
Some outdoor grills use hoses with fittings crimped on the end. If the fitting has come off, check the hose to see if it is cracked or dried up. If this is the case, replace the hose. You should probably replace the connector even if the hose is good; the crimp is not trustworthy if it has come apart.
Less common is welded or brazed connections. If this has come apart, have it professionally repaired or buy a new connector assembly
SOURCE: Gas not getting to grill
Two things could be wrong. Tank valve could be bad, not allowing gas to flow. Or regulator could be bad not allowing gas to pass. Try taking the tank off and pushing a screwdriver into the end of it with the tank open, if gas doesn't come out tank valve is bad, valve has a spring in it to shut down if starts leaking. If tank valve is good regulator must be bad. I am leaning more towards to the tank valve.
