Televison & Video Logo
Caleb Rowe Posted on Jun 04, 2019
How do I fix my Vizio Model VX37L HDTV10A distorted colors
It has sound, and picture but the colors are misplaced, very bright blue,purple and red colors in places there shouldn't be. PLEASE HELP!!!
beff contu
Level 1:
  • Contributor 4 Answers
  • Posted on Jun 04, 2019
beff contu
Contributor
Level 1:
Answers
Questions
0
Helped
783
Points
13
Its time for another Tv set man
the screen gone bad
  • Caleb Rowe
    Caleb Rowe Jun 05, 2019
    Thank you I was holding out just in case there’s was a cheap fix
2 Related Answers
vinceisaac
francoise cleofas
  • 2432 Answers
  • Posted on Mar 10, 2013
SOURCE: Missing colors on vizio vx37l hdtv10a. Powers up and has picture but looks like its missing reds
check for a loose connection at the t-con board fixed the lvds cable.
gopakumarg43
  • 76851 Answers
  • Posted on Oct 20, 2016
SOURCE: I have a Vizio model# VX37L HDTV10A. Why does it look like a negative but only with bright color when powered on. I took back off everything looks good caps and allplz let me know asap
Check and replace the T'Con board.
Vizio vx37l hdtv10a
If recently bought, take it back as a default.good luck..
1helpful
Vizio vx42l hdtv10a preset picture too bright
You should be able to change the brightness levels in the menu.
Vizio TV has purple haze and colored stripes on the sides of the picture.
You possibly have a failing hi-voltage module or fly-back transformer going bad. If it has a fly-back transformer, It's not worth the trouble. Some repair shops will sell you a module. Call a repair shop for help.
Wavy picture with blue and purple color.
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
1helpful
Purple and green color
It sounds like a convergence problem to me. I had the same problem with my set and fixed it myself using a kit I bought from www.TvRepairKits.com. These guys rock!
Vizio vx37l green/red/blue sparkles
Call Vizio tech support and start a case. i am having the same issues with mine and i have sent it back. they will be replacing it this time.
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
