Samsung Galaxy Note 3 Logo
Jason Varnum Posted on Jun 03, 2019
How do I get my galaxy note 5 to pair with road king rk200 wireless Head set
4 Related Answers
Anonymous
  • Posted on Nov 27, 2008
SOURCE: the phone with which my
you have to hold the button on the top till the blue stays on then go in your phone to the blue tooth settings and search for the device it should find it and be paired again
Anonymous
  • 5 Answers
  • Posted on Apr 24, 2010
SOURCE: pair to a sony ericsson w760a to a just wireless
Put your device in search mode.
Put the bt-35k2 headset in pairing mode.
(Press the ON button but hold it down for about 6 seconds. As I recall, it will flash intermittent blue and red; either way, you will certainly see flash sequence that is not normal "blue" mode.)
Once device detects headset, you'll be prompted for passkey; enter 0000. Pairing will complete once authenticated.
JMBrophy
Mark Brophy
  • 752 Answers
  • Posted on Sep 19, 2015
SOURCE: My Galaxy Note 5 is set up in Chinese. How do I get it into English?
How to Change the Language on Samsung GALAXY Tab try this link
Lawrence Oravetz
  • 10558 Answers
  • Posted on Feb 15, 2018
SOURCE: I have a metro pcs samsung galaxy note 5 with a cricket wireless sim card what network to set as default settings T-Mobile, version or at&t because all three came up
I think Cricket uses Verizon
My Galaxy note 5 is not pairing with my K100 speakerphone. I have tried to pair it by manual instructions. Any advice is welcome
Try the simple basics first. Turn both items off, give it a minute then turn both units back on. Make sure both units are in pairing mode.
You might have to go into Settings on your Note 5 and turn the 'phone visibility' on.
Check there is nothing else paired to each unit and then retry to pair the Note to the speakerphone.
How can I wire a Road King 5-wire to a 4-pin Galaxy Saturn?
Search for CB TRICKS on the internet. All the information you could ever need for this type of information is at that website.
How can I connect a Road King 5-wire to Galaxy Saturn 4 pin?
attach the wires according to the schematic you got with the radio telling you what wires do what. Those wire go on pins 1 - 4 The yellow wire is not connected.
How can I reset my Galaxy tab 2 7 to its original settings?
Samsung Galaxy Tab 2 7.0 - How to perform a hard reset with the ...
https://www.androidpit.com/.../samsung-galaxy-tab-2-7-0-how-to-perfor...
Jun 18, 2014 - Samsung Galaxy Tab 2 7.0 - How to perform a hard reset with the ... From the Backup & restore section, ensure the appropriate account is ... In Menu mode, select Settings ? Privacy ? Factory data reset ? Reset Tablet? ... Samsung Galaxy Tab 2 10.1 - How to perform a hard ...
Jun 18, 2014
How to Hard Reset the Galaxy Tab 3 - Android Forum ...
May 7, 2014
More results from www.androidpit.com
Galaxy Note 5: How to Perform Soft & Hard Reset
www.technipages.com/galaxy-note-5-how-to-reset
Aug 23, 2015 - If you want to sell or give away your Samsung Galaxy Note 5, or if you're ... The hard reset will wipe all files off of the internal memory, as well as ... your phone and just perform a factory reset as a way to make it their own. ... November 7, 2015 at 3:44 pm ... I have problem with my Samsung Galaxy tab 2 ...
How to Hard Reset/Factory Reset Samsung Galaxy Tab 2 7.0
? 6:01
https://www.youtube.com/watch?v=7sbgN0PxMzc
May 2, 2013 - Uploaded by HARD RESET KING
How to Hard Reset/Factory Reset Samsung Galaxy Tab 2 7.0Android 4.0 ... hi I got the same one as you and ...
2answers
How to connect Motorola S10-HD Universal Bluetooth Stereo Headphones to Iphone 6 plus? Thanks!
turn bluetooth on ,on both units,search for devices with your phone when it finds head phones click on it and pair them
1helpful
2answers
I cant connect it to my new Galaxy note 4
Irma
Turn on Bluetooth on Galaxy Note 4 via settings Bluetooth. Then H730 Pair and Connect
Mark
Motorola Support
Android problems
Not sure how you are connecting the devices, so I'll assuming by a USB cable. In Android you have to change your device from charge only, to storage mode. If you are connecting by bluetooth, you have to pair the devices. Pairing on Android is fairly robust, but Windows and be a challenge. Often times the bluetooth drives are flakey, particularly with Windows XP, etc.
1helpful
Galaxy 959 wire mic for road king 56
1- Shield & Red
2- White
3- Blue
4- Black
Yellow NC
What size star wrench to use when changing the transmission fluid on a 2008 Road King
I have a 2008 Road King Classic (FLHRC) and on mine, both the oil drain and transmission drain is a hex head bolt, 5/8" I seem to recall.
2answers
I have the mini bluetooth 2.1 usb micro adapter. The device works with my keyboard & mouse & can see my blueant head phones but the music will not tranfer to the headphones it just plays with the...
Go to this page, it will answer any question concerning the blueant .. including pairing to your phone .. activating your blueant etc http://www.blueant.com.au/index.phpalso gives you step by step instructions on codes, pairing etc
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mike Cairns
Mike Cairns
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
