Probably not a house fuse. Typically good or bad!! Have you tried it in a totally different outlet?? Could be a bad connection of your circuit breaker to the bus bar in your circuit breaker panel. Try it on an outlet on a different breaker. Or have someone check the power at the outlet when it is running and see if the voltage is dropping.
Power being interuppted could be anything from a bad fuse , bad fuse holder, bad solder connections on the main board. Bad breaker in your panel. Start by plugging it into an outlet you know is on a different breaker than the on it is on now. See if it does the same thing. If it works ok, then problem with power to the other outlet. If it does the same thing problem inside of unit. PF is Power Failure, now we have to figure out why.
I just had the same problem with my ge spacemaker microwave model number JVM1490bd. I removed the grill on the top of the microwave with two screws on top. There is one screw that holds the front touch pad on, remove the screw and lift up to remove. The damper assembly is on the upper left, my door was sticking and didn't make the limit switch. I moved the door back and forth making the switch a couple times and that solved the problem.
Hi, try the microwave in another outlet, if it works there then the first outlet is bad but if the microwave does not work in another outlet then the microwave is faulty and you need to take it back to the store and get another one as a replacement.. Hope it helps......
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
Here is a tip that will help you to figure out what is wrong with your
Microwave Oven....
Generally, you get something unless the fuse inside is blown. There is generally a fuse inside the unit when you remove the button package. First, make sure that the outlet you have is good. Plug something else into it and see that it works.
Could you explain in more detail what you mean when you said you moved around the cord and pushed and wiggled the oven?
I'm concrened about a bad cord or outlet, which could lead to a fire.
