Hello, does anything come back on when you re-energize the TV? If it powers up go to menu and select the input for your PS4 otherwise it sounds like a power issue on the TV. Time for either warranty or local TV Repair. Good luck
PS4 needs high resolution so maybe your TV cannot adapt to your PS$ unit. You try to isolate and connect your PS4 with another TV with latest models
SOURCE: when i turn on y Vizio LCD TV theres a blue screen that says no
Your TV is probably in RGB mode which means its looking for a computer signal. Plug a computer into your TV and then it will stay on. Then you can change it back to TV mode.
SOURCE: Vizio TV wont turn on after three weeks no use
My vizio recently did the same exact thing. Vizio sent an HDTV tech out to fix it and it was the power board. He put a new board in (took 15 min) and the tv works like new.
SOURCE: TV will not turn on. Model SV370XVT 1 yr old Made
U have a front screen panel LED light indication are flashing or totally dead,no LED light indication at all?Yes,than the tv power supply board is the causes and the problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv power supply board for the replacement.
Testimonial: "Received an adequate answer to my problem very quickly."
SOURCE: Hey there, I have a 6 month old vizio 32" LCD 60hz
Most probably the mainboard of the TV has a problem. But no worries as it is only 6 months old call up Vizio and they'll replace it for you free of charge :)
