Question about Canon Cameras
My canon elph 340 HS always downloads pics to my computer in duplicate. how can I stop the duplicates?
6ya staff
SOURCE:
pontelemon
pontelemon
  • 538 Answers
SOURCE: Reset the camera to record once, not duplicates of the same pic
There is a small button on top, right next to the Mode Dial. That's the button.
Posted on Mar 18, 2009
Anonymous
SOURCE: My phone sends duplicate texts
this is late, but for anyone else wanting to know, this occurs when your message reaches the companies smsc [short message service centre] it fails to send to the recipient at first, so it stores itself on the centre [or logs] and will attempt to send multiple times over the course of the next 48-72 hours depending on how they have their engineering setup. This can result in multiple sms, this is most likely not your handset, but in rare cases with certain phones, like blackberry handsets and some older symbian [vulnerable to hackers] can do this. So call your provider and get them to raise a fault through their networks, then if it fails, look into your handset.
Posted on Dec 19, 2009
Anonymous
  • 3 Answers
SOURCE: All songs are duplicated in the song list
select them and delete them
Posted on Mar 11, 2010
albertperamb
Albert Paul
  • 148 Answers
SOURCE: How do you remove the _palbtn ? its duplicating my
_palbtn is a cache or preview feature of nokia.It is used to show taken pictures speedly by creating it's duplicate(only size will be some kb's) You can manually delete _palbtn by going to filemanager and goto images goto _palbtn delete it.This feature cannot be turned off.Thanks
Posted on Jul 27, 2010
fungasgrafx2
SOURCE: Targer drive not ready.
"Target overflow" just means that the disc being used to make the copy doesn't match in size. "4.7GB" to the master disc. Sometimes this occurs when you make a mistake thinking the disc in the copy slot is a DVD blank but it may be a CD-R blank(by accident) or sometimes the Master disc is a BD-R and trying to copy to a regular DVD-R (won't fit)
"Source drive not ready" is when the Master disc keeps spinning in the attempt to read. The "culprit" alot of times is the brand, or scratched, dirty, corrupted discs.
Make a copy of the master again (if possible and on your PC with a different brand of disc) then use the new Master to make the multi-discs you want.
"Target drive not ready"
is when a disc with information already on it, is in the copier (can't copy over it) sometimes we make mistakes and put the Master in the copier and vice versa : )
or no disc in it at all, and or some sort of incompatible blank media.
I have a 7 disc duplicator by Pioneer and I found that in the last few years since I've had it (since 2005)
I ran into the above situations alot.
I use it as a standalone (not hooked up to any PC etc)
It still works great but I find that was having a brand name issue with the discs; certain discs that it used to read in the Master/Source drive like Taiyo Yuden, Memorex, Ridata, SKMAX, and Phillips, suddenly don't want to read properly when inserted. The discs keeps spinning and then when you press "copy" it says "Target overflow" or "Source drive not ready" I found that solution I mentioned above with the changing of the disc brand helps fix the situation. I didn't want to hurt my brain trying to figure out what it could be as I use my duplicator for business and time is money.
Through trial and error I end up just making duplicates from my PC on different brands (cheaper unknown brands work fine) and then using the "new master" made from these is the only way I can duplicate..weird!
P.S sometimes the lens may need an old fashioned cleaning with a lens cleaner or Dust blower.
Once in a while one or two of the doors get stuck even when all 7 discs are completed...just take a q-tip with vaseline and put it on the track wheel for some lubrication and the door will open up easier.
Just some tips from someone who's had their player a long time
Hope this helps anyone in need out : )
Posted on Oct 05, 2010
Where is the self timer located for the CANON Powershot ELPH 340 HS?
Have a look at page 32 on this manual
https://www.manualowl.com/m/Canon/PowerShot-ELPH-340-HS/Manual/407032?page=32
Jul 17, 2015 | Canon Cameras
How do i unlock the wifi password on my canon elph 340 hs
To determine the access point password, check on the access point itself or refer to the user
Jan 04, 2015 | Canon PowerShot Cameras
My flash stopped working i have CANON 340 hs powershot n when i took without flash its giving me results
Try to reset the camera settings, then press the flash button (lightning symbol) and make sure it's set to ON mode.
if it still does not work you might need to replace it
Dec 05, 2014 | Canon PowerShot ELPH 340 HS Black Digital...
Where do I find the authentication code ?
I seem to think that this is located on the box it came in around the area on the bar code.
Dec 04, 2014 | Canon PowerShot ELPH 340 HS Black Digital...
What is the authentication code for my Powershot canon Elph 340HS?
Once you connect your camera to the Canon Image Gateway site via wifi, you will see an authentication code on the camera. See Pages 87 & 88 in the manual here: https://www.manualowl.com/m/Canon/PowerShot-ELPH-340-HS/Manual/407032?page=87
Hope this helps you!
Dec 04, 2014 | Canon Cameras
Canon powershot elph 340 hs
You either need a larger SD card or to reduce the quality of the video you're shooting.
Sep 01, 2014 | Canon PowerShot ELPH 320HS Black...
When transferring pics to computer from camera it will transfer some and then not transfer others saying they are duplicates when they are not. How do i get these others pics onto the computer?Ads by...
Your camera is not numbering consecutively...it is starting over each time...hence the duplicate numbers. You can use a card reader to download the pics to a folder you create on your desktop. From there, you can right-click the duplicates and rename them.
Aug 06, 2010 | Kodak EasyShare C913 Digital Camera
Picture download
Your camera is not numbering the pics consecutively. It is duplicating the numbers and your computer thinks the pics are already there. You are going to have to figure out the duplicates and download them to a separate folder and then rename them.
Dec 15, 2009 | Kodak EasyShare C913 Digital Camera
Cameras Logo
64 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Ekse
Poul Brinchs Larsen
Are you a Canon Camera Expert? Answer questions, earn points and help others
