Question about Hobart Dishwashers
Does a Hobart LXeR Dishwasher require a backflow
4 Suggested Answers
6ya staff
SOURCE:
Rancher34b
  • 5 Answers
SOURCE: when draining water out of the sink, it backflows
Actually no they do not have a back flow preventer, make sure the dishwasher drain connection is installed on top of the "P" trap, if it is then you are having drain problems , remove and clean the "P" trap if it not clodded then you need your pipes cleaned out if it is backing up in dishwasher.. Do it sooner than later or may become totally stopped up..
Posted on Feb 01, 2010
GPEC
  • 12 Answers
SOURCE: backflow - want to be charged by council to monitor
All Hobart AM-14 come with a vacuum breaker which prevents any back flow from occurring.
Regards
Posted on Mar 12, 2010
vestxre
  • 119 Answers
SOURCE: i have a hobart lxih that is leaking from the
Make sure your flow pressure is 15 to 25 PSI. Flow pressure below 15 PSI will cause the vacuum breaker to leak.
Posted on Jul 19, 2010
Hobart SR24H Dishwasher. What dishwasher detergent do I use and how much per cycle?
Hobart are commercial machines so require commercial chemicals. Companies like Johnson diverse and ecolab are the usual favourites, but wherever you buy your cleaning equipment from will have a brand they can sell you. Most companies also provide and setup automatic dispensers with their chemicals. Find a supplier and ask them what they can do for you
Sep 13, 2018 | Hobart Dishwashers
Can backflow mounted to sink be moved under sink?
Hi Del:
I'm not sure what you mean by "backflow".
How is this related to your dishwasher?
The discharge from the dishwasher has to be connected to the drain from the sink, upstream of the trap that protects the sink.
A hand sprayer is typically integrated with the sink faucet.
Reply as a COMMENT to this post to discuss.
Cheers
Mar 09, 2016 | Kenmore Dishwashers
Strong gas fumes when burner is on to bring up wash temp just had burner replaced
there are only two reasons that this would happen.
1. The burners are not adjusted correctly for optimal performance and they are running rich. Could be a gas pressure issue causing this or the orifice and fuel air adjustment needs checked.
2. The ventilation is not adequate.
You need to measure the CO level if this is not vented to the outside. If it is then you need to make sure the flu is adequate and there are in temp inversion issues or room air causing backflow etc.
Jun 05, 2013 | Hobart C44a Commercial Dishwasher
Hobart LX 30 undercounter dishwasher, commercial Does this model require booster?
Most of the Hobart LX series of dishwashers have their own built-in booster heaters. To check for one, remove the lower front panel (2 screws). The booster heater, if present, will be a stainless steel tank on the left side. If it doesn't have a built in booster heater then it was meant to be used with chemical sanitizer instead.
Jun 29, 2011 | Hobart 24 in. LXIH-3 Built-in Dishwasher
I have a hobart lxih that is leaking from the backflow valve even after replacing it
Jun 18, 2010 | Hobart 25 in. LXIH-4 Built-in Dishwasher
Backflow - want to be charged by council to monitor
Regards
Mar 12, 2010 | Hobart 42 in. AM14C-154 Free-standing...
No water pressure in rinse cycle
AM 14's need 20 PSI flow rate of rinse. Is your pressure gauge accurate? Could the rinse nozzles be blocked with scale? If you remove them to clean, make sure they go back in the same positions. Note the upper arm has one each side pointing up, to clean the top of the machine. Check that the upper rinse arm has it's thrust washer under it's hub.
May 05, 2009 | Hobart AM14-253 Free-standing Dishwasher
Dishwashers Logo
62 people viewed this question
Top Hobart Dishwashers Experts
GPEC
Level 1 Expert
Jason
Marvin
Marvin
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
