With POP3 the e-mail is stored on your computer, while with IMAP the e-mails are stored on the server. I prefer IMAP myself since I can access my e-mail from multiple devices.
https://computer.howstuffworks.com/e-mail-messaging/email4.htm
SOURCE: the issue is: Unable to
Either you have the server name incorrectly setup in Outlook Express, or your internet connection is down currently. Check with your ISP to fix this problem.
SOURCE: OE error says host pop3 cannot be found
You're pop3 server has 2 names, the incoming mail server name and the outgoing mail server name.
The names are usually written like for example; "incoming.verizon.net" and "outgoing.verizon.net" or like: "pop.gmail.net" and "smtp.gmail.net".
For your ISP find out what the server's names and install them in the appropriate spots -Spelling counts (capitalization does not count)!!!! Observe where the periods go also.
Good Luck!
Rich
SOURCE: I get this error when trying to
It looks as if the server name is not complete. where is your email coming from? you'll need to know that and the email server (for example: mail.ptd.net for penteledata customers). Or, pop.gmail.com for gmail users. Get that server, then go into your account settings and put the server name into the Incoming Server blank. once you do that and save it (also make sure your outgoing server is correct) you should be fine.
