Home Logo
Fred Van Nostrand Posted on May 29, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can I remove a Delta faucet handle that has no set screw?
Peter Muisyo
Level 1:
  • Contributor 2 Answers
  • Posted on Apr 06, 2021
Peter Muisyo
Contributor
Level 1:
Answers
Questions
0
Helped
14256
Points
Step 1: Turn Off the Water
For this method, turning off the water under the sink is a safety precaution
Step 2: Twist the Handle's Base
While holding the faucet's handle arm in place, rotate its base counterclockwise, and remove it.
Step 3: Remove the Screw
After removing the faucet's base, remove the screw inside. Hold the underneath centerpiece and use a screwdriver.
Step 4: Pull Out the Cartridge
After the screw is out, you will see a white cartridge underneath. Remove it using nosed needle pliers and replace them. Unfortunately, many people have expressed frustrations while removing cartridges using pliers. To avoid such, buy new bathroom faucet renowned brands like Delta and Moer. Such brands offer full support in case of a problem, and you will always get the replacements you need.
CJ Rock
Level 3:
  • Delta Master 4,417 Answers
  • Posted on Mar 29, 2021
CJ Rock
Delta Master
Level 3:
Answers
4417
Questions
0
Helped
1642092
Points
14985
There will be a set screw beneath a decorative cap or behind a tiny red/blue plug.
Paul Bade
Level 3:
  • Master 1,818 Answers
  • Posted on Mar 28, 2021
Paul Bade
Master
Level 3:
Answers
1818
Questions
Helped
574151
Points
5816
The following answer is generic for Delta two-handle faucets since no model or type description was given.
Every Delta faucet with separate hot - cold valves that I have seen has a screw hidden under a trim cap on the top of the handle. The cap pops off with fingernails or a small flat-blade screw driver under the rim. Remove the screw with a #2 Philips screwdriver and pull the handle straight up (sink faucet). Usually it comes off easily. If it doesn't come off, and there is a lot of lime buildup around the faucet due to hard water leaking out, you may have to soak it with vinegar or CLR to soften the lime in the shaft. That would be unusual; lime doesn't generally stick to plastic.
Tom Chichester
Level 3:
Top Expert:
  • Delta Master 62,329 Answers
Tom Chichester
Delta Master
Level 3:
Top Expert:
Answers
62329
Questions
0
Helped
670715
Points
975369
Use the special tool for pulling handles.
5 Related Answers
Donni Steen
  • 687 Answers
  • Posted on Apr 06, 2009
SOURCE: Adjusting single leaver faucet handle
The little wrench tightens the tension ring that fits on the inside of the retaining nut right under the handle. You fit the little "arms" in the notches.
Donni Steen
  • 687 Answers
  • Posted on Apr 10, 2009
SOURCE: replace delta single handle shower cylinder
Yes, I believe this unit uses a cartridge right? They do fit a little tight due to the small washers on the back side of the cartridge. If this is the one I'm thinking of, there are two leg like appendenges that come off the back and fit into small holes at the back of the manifold or what some call mixing valve housing.
Anonymous
  • 3006 Answers
  • Posted on Jul 22, 2009
SOURCE: I cannot get the set screw out of a Delta
You can't apply any worthwhile heat to try and free this off without causing further damage, but if you have a pipe freezing kit handy you can try freezing it a few times and then pouring boiling water over it to thaw it suddenly. The thermal shock sometimes works but it's not a sure enough thing to be worth specially buying a freezing kit for.
That leaves two other possibilities: drill the screw out and get a replacement (or adapt one from another machine screw) or partially drill it and use a very small stud extractor. If the screw is brass then just drill it out in my experience as stud extractors just don't work on small diameter non ferrous materials.
If you drill the screw out then you need to use a drill bit small enough to go down the centre of the screw without damaging the threads, but large enough to leave it sufficiently thin-walled to be able to collapse inwards when you subsequently winkle it out. Usually I find that a pin punch driven anticlockwise against the thin rim left after drilling does the job.
Anonymous
  • 582 Answers
  • Posted on Sep 16, 2009
SOURCE: delta single handle faucet leaks
BEHIND THE HANDLE THERE SHOULD BE A SET SCREW THAT HOLDS THE HANDLE ON THE STEM. THE SET SCREW WILL BE BEHIND THE LONGEST PART OF THE HANDLE LOOK AROUND BACK OF THE HANDLE. AFTER REMOVING THE HANDLA THERE WILL BE A STEM AND A NUT THAT HOLDS THE ASSEMBLY IN THE HOUSING
Anonymous
  • 448 Answers
  • Posted on Oct 03, 2009
SOURCE: How do I remove delta 470 kitchen faucet? It won't swivel
If the 470 is typical, there should be two large nylon nuts on the bottom of the faucet tubes that hold the faucet to the sink. First, turn the water off, then open the faucet to drain any pressure. Next, disconnect the feed lines (hot and cold) that connect to the faucet from under the sink (be prepared for some water back flow, so paper towels would be a good idea). After the feed lines are disconnected, you should be able to reach up (usually behind the back of the sink basin) and access the two large nylon nuts (one on the cold and one on the hot). These nuts typically have raised portions so that you can get a grip on them. If you are lucky, you will be able to turn them (lefty loosey, righty tighty) by hand. If not you may have to work for some time with various pliers or other tools getting them to turn. Once you have them off, the faucet will simply lift up from the sink. Installation of another faucet should simply be the reverse procedure.
Good luck.
1helpful
Have a 2011 delta purchased kitchen faucet, 2 handle, no handle set screws, how to remove handle
They should simply twist off (unscrew)from the base. Assuming thus is a two handle faucet the "body" right below the handle will simply unscrew reveling the cartridge underneath. Hope this helps!
Where is the grub screw that has to be removed as I can't find it?
plumbing - How do I remove a stuck faucet/tap cover ...
diy.stackexchange.com/questions/.../how-do-i-remove-a-stuck-faucet-tap...
Apr 18, 2011 - Anybody can ask a question; Anybody can answer; The best ... There are total six faucets in a bathroom, two made into a bathroom basin ... The other possibility is that there's a small plastic "decorative" cap covering the screw.
How-To: Replace A Shower Faucet Cartridge ' Toolmonger
toolmonger.com/2009/12/01/how-to-replace-a-shower-faucet-cartridge/
Dec 1, 2009 - In many modern shower faucets like Delta and Moen (which is what I have) .... About a year ago, one of the bathtub faucets in my other bathroom jammedopen. .... the exact faucet I have in my shower, so you answered my first question, ...I can tighten and loosen the screw but the handle just won't come off!
Problem Removing Handle Off Of Delta Monitor 1400 Series ...
www.diychatroom.com/.../problem-removing-handle-off-delta-monitor-...
May 20, 2009 - 15 posts - ‎12 authors
... from a Delta Monitor 1400 series tub/shower single handle faucet. ... sorry for the REALLY sxxxxx question. which way to turn (loosen) the set screw. ... only suggestions i have on the issue. when a setscrew will not back off i ...
REMOVAL OF STUCK CURVED FAUCET HANDLE WITH HEX SCREW ' DIY Forums
www.diyforums.net/removal-of-stuck-curved-faucet-handle-with-hex-sc...
Feb 03, 2016 • Home
How to fix delta shower single knob faucet
Take handle off (either set-screw from side or bottom of handle, or phillips screw under cap on end of handle), pull off sleeve that's behind handle, unscrew nut that holds cartridge (strap wrench works great) and pull cartridge out.
Delta faucets troubleshooting
Spray with lubricant and let it work - you may have to spray more than
once - main thing is do not strip the screw head....try a long handled
screw driver.
Regards,
Dennis
How to remove handles
I have extracted the legend of figure 5B of the installation instruction here for your reference:
Remove handle from the faucet by loosening set screw (1) and pulling off handle. Once handle is removed, loosen set screw (2) from the bottom of the handle, remove accent (3), replace with new accent, tighten set screw (2), replace handle on faucet and tighten set screw (1).
Here is the link for the installation instruction:
http://www.deltafaucet.com/media/MandI/40033RevC.pdf
1helpful
Delta single handle faucet leaks
2answers
Leaking hot water from delta single handle facuet
I have to assume you've unscrewed the face plate, not removed it, because you can't do that without taking the handle off. Delta handle usually come off by unscrewing an allen (set) screw just under the handle itself. Sometimes these are covered by a plastic plug.
Occasionally, even after you've completely removed the set screw, the handle still won't come off. Wiggling and pulling for a few minutes will generally get it off. If not, then a hacksaw, new handle and new cartridge are the answer.
If the allen screw is stripped and that's why it won't ome off, see above.
Good Luck.
Replace entire valve assembly
You can drill a small hole into the set-screw and use an easyout to extract the set screw
Leaking Delta kitchen faucet dual handle
Pry the hot/cold button off the top of the handle. Make sure the water is turned off below the sink.
Under the button should be screws. Remove the screws. Pry the handle off. Remove the stems by lifting then out.
That should give you access to the washers you need to change.
Top Delta Home Experts
john h
Paul Carew
Paul Bade
Are you a Delta Home Expert? Answer questions, earn points and help others
