SOURCE: Continuous Flash of Visual Ringer(Uniden DECT 6.0 Cordless)
UNIDEN MODEL EZX290 HANDSET>>>VISUAL RINGET AT TOP (YELLOW LED) FLASHES. HOW DO I TURN THT OFF?
SOURCE: the visual ringer keeps flashing on my uniden cordless phone
I CALLED UNIDEN WITH THE SAME PROBLEM.
THE VISUAL RINGER IS FLASHING WHEN YOU HAVE OLD EMAILS. YOU HAVE TO DELETE THE OLD EMAILS
SOURCE: The visual ringer switch on
I will suggest you reset your phone, Turn
off the phone, remove the AC adapter, press and hold the page/call
button that is on the phone and plug back your Ac adapter, this will fix
the problem. If that did not fix the problem, let me know.
SOURCE: The visual ringer will not flashing.
At an educated guess sounds like dial tone is set to decadic if there are two phones the other phone will set off ringer when numbers dialed. May need to get phone provider to change dial mode in exchange line interface circuit to be Dual tone Multi Frequency Dialing and then switch phones to Tone dialing rather than pulse dialing.
You can silence the ringers on the base and handsets at the same time. It doesn't affect the visual ringer on the phone in standby, press and hold Silent on the base. The phone automatically turns on the answering system and shows Do Not Disturb in the display on handset. (The answering system answers any incoming calls without playing anything through the speaker.)To cancel, press Silent again. If you turn the answering system off while Silent Mode is on, the phone turns off Silent Mode.
