Radio Communications Logo
D
DAVE Posted on May 28, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
POT locations for RF meter/modulation/RF power on Galaxy 47HP radio or give website Dave
Clint Millett
Level 2:
Habit-Forming:
Scholar:
  • Expert 97 Answers
  • Posted on Jun 04, 2019
Clint Millett
Expert
Level 2:
Habit-Forming:
Scholar:
Answers
97
Questions
Helped
39907
Points
129
Google found this on the Galaxy site: https://sites.google.com/site/galaxyradios/amateur-and-cb-radios/amateur-radios/galaxy-dx-47hp
5 Related Answers
Anonymous
  • 83 Answers
  • Posted on Jul 30, 2007
SOURCE: 148NW ST No TX AM or SSB
finals need to be replaced, as they are fried,, hence no output,,and if you are lucky you haven't fried the pre-amp as yet....as the pre amp is REAL EXPENSIVE....so stop keying it up
Anonymous
  • 219 Answers
  • Posted on May 01, 2010
SOURCE: G959 mod meter will not work but modulation is 100% others rfine?
If its the meter on the radio don't worry about it they do go bad but it won't effect the radio. My shops in North Florida. And no I have no web site at this time.
Anonymous
  • 1274 Answers
  • Posted on Jun 02, 2010
SOURCE: galaxy 33 no audio from speaker. i have a galaxy
Check the receive wire on the plug end of the mike, and the receive wire inside of the mike, just a starting point. ..hope this was helpful.....
ADRIAN
  • 313 Answers
  • Posted on Jul 25, 2010
SOURCE: Have Cobra 29 LTD Classic, no sound when hooked to
check the squelch by turning all the way both ways. check the external speaker socket. if it is the swicthing type it could be either bad conntact or dry joints. try an external speaker to see if that works. another thing is I believe it wont work if the microphone is not pluged in or connection fault there. Good luck.
Anonymous
  • 64 Answers
  • Posted on Sep 12, 2010
SOURCE: radio will transmit some of the time
Sounds like a heat sensitive problem to me. See the above listed problem and solution. Also the heat could be coming from over heating even from a high SWR as suggested.
Transmits and receives no modulation out
I am not an expert but I think there can be little or no modulation of the carrier wave unless there is an audio input to the modulator. Like any audio amplifier a transmitter modulator (amplitude modulation) is quiescent without an input.
If the modulation amplifier and audio pre-amp are working and modulating the carrier wave and the antenna is ok then audio modulated radio frequency must be being transmitted.
It would be an extremely good quality CB that had a modulation meter. Mostly all they have is a meter giving an indication of the rf power being sent to the antenna and that rf (radio frequency) power would be the same whether modulated or unmodulated.
The modulation envelope, incidentally, is traditionally viewed or measured with an oscilloscope.
The indicated rf power could be verified using a field strength meter but the only practical way to discover if a standard CB is transmitting modulated rf is to listen to the transmission on a suitable receiver. If the squelch is turned down it will be obvious if the rf carrier wave is being received as the hiss would be silenced. If no audio is received it can be assumed none is being transmitted.
I suggest you try another microphone and lead and if that doesn't work it is clearly a job for a repair shop.
1helpful
What is Dead Key on a CB Radio?
Deadkey is slang it is CW or Carrier wave which is RF power produced before modulation/audio is mixed in which stimulates PEP wattage slang being SWING WATTS. A Watt Meter is used to measure it which is often a combination device Wattage/SWR/Modulation meter.
How to trun the power up on my galaxy dx 55v
AM CARRIER POWER HIGH: VR-13 pot. for RF power adjust
AM CARRIER POWER LOW: VR-16 rf power adjust
SSB dead key & TX frequency problems
Check C-144, c-149, c-153, c-154 using an ESR meter.
When my truck is running the radio works fine until I key up then the RF meter goes to 9 and says there and the red light stays on this is a Galaxy DX 98 VHP radio
is it acting like its keying up fulll power and no modulation or very very low modulation.. its prob has a shorted "am regulator" .. the big transistor in the back corner by the power wire connector.
2answers
The galaxy radio is a 2980 and the RF power does not work how do u fix it or were on the board can I fix it
are you talking about the variable rf knob or do you not have rf power output? check it to a radio next to you with no antenna on the checking radio. and see if it will move the meter.. if it does they change the rf final transistor..
1helpful
5helpful
2answers
How to adjust frequency on transmit??? Galaxy
hELLO THERE
hERE IS SOME MODIFICATIONS FOR THIS RADIO
Galaxy Mods DX 2527 - VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR11...Driver Bias, VR12...SSB ALC, VR13...Hi Power, VR14...AMC, VR15...AM Low Power, VR16...SSB Low Power, VC 1....10.240, VC 2....10.240. DX 2517- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5....FM Deviation, VR 6....SSB Carrier Balance, VR 7....TX Offset, VR 8....CW Beep Level, VR 9....RF Meter, VR10...Final Bias, VR11...Final Bias, VR12...Driver Bias, VR13...SSB ALC, VR14...AM/FM High Power, VR15...AM Modulation Meter, VR16...AM Modulation, VR17...SSB Power, VR18...AM/FM Low Power, VR601..13.8 Volt Power Supply. DX 22B- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR11...Driver Bias, VR12...SSB ALC, VR13...High Power, VR14...AMC, VR15...AM Low Power, VR16...SSB Low Power, VR21...TX Offset, VC 1....10.240, VC 2....10.240. DX 11B- VR 1....AM/FM S-Meter, VR 2....SSB/CW S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR10...Final Bias, VR11...Driver Bias, VR12...SSB ALC, VR13...AM/FM High Power, VR14...AM Modulation, VR16...CW Tone Level, VR20...Final Bias, VR21...TX Offset, VR601..13.8 Volt Power Supply, VR803..AM/FM Low Power. DX 77HML, DX 88HL, and DX 99V- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR10...Final Bias, VR11...Driver Bias, VR12...SSB ALC, VR13...AM/FM High Power, VR14...AM Modulation, VR16...AM/FM Low Power, VR20...Final Bias, VR21...TX Offset.
Unmarked VR in R189..AM/FM Medium Power for DX 77HML only. DX 33HML, DX 44V, DX 55V, DX 66V, and DX 73V- VR 1....AM/FM S-Meter, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 8....RF Meter, VR12...Low Power AM Modulation, VR13...AM/FM High Power, VR14...High Power AM Modulation, VR16...AM/FM Low Power.
Unmarked VR in R188..AM/FM Medium Power (DX 33HML only)
Unmarked VR in C139..Med Power AM modulation (DX 33HML only) DX 949,DX 959- VR 1....AM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM Squelch Range, VR 6.....SSB Carrier Balance, VR 7....TX Offset, VR 9....RF Meter, VR10...Final Bias, VR12...Driver Bias, VR13...SSB ALC, VR14...AM High Power, VR15...AM Modulation Meter, VR16...AM Modulation, VR17...SSB Power, VR18...AM Low Power, VC1....10.240. DX 2517 and DX 2527-
Symptom:Buzzing or motorboating sound in either the transmit or receive.
Problem: TR602 is oscillating
Cure: Replace C602 with a .01uF cap {Cap is located in the power supply board}.
RG 66,99,DX2517 Replace Q54 2SB754 60watt 7A with a higher power 2SB817 100 Watt 12A. Derating of this component will cool operation, provide better voltage stability,decrease wobble, allow voltage increase to 14.5 volts comfortably. (replace 10 volt caps in this section of the radio to a minimum of 16 volts before increasing supply voltage to this level)and provide faster swing rise time, Replace Q37 2SA473 to a 2SA1012-0 or ECG153 this will improve the clarity and volume of the modulation and it will also run a lot cooler.
I HAVE A 2517 GALAXY RADIO IT IS MUFFELD ON TRANSMIT
What is the power output on a watt meter telling you? if it is up above an 8 watt dead key with the rf power turned all the way down, someone has turned up the radio inside and you will ned to turn it back inside to get about a 2 or 3 watt dead key with the rf power turned all the way down on the outside knob on the face of the radio. to do this, you will need to locate the VR18 pot for low power on am/fm and the VR14 pot for high power on am/fm and adjust accordingly, you are most likely overdriving the radio in some way and if you are not familiar doing this sort of thing, then my suggestion would be for you to take it to your nearest electronics repair tech and have them do it for you. It is not a costly procedure and you will be better off to have an experienced tech in there. Also if you are running a power mic on it, try turning it down some or going back to the stock mic to see if the problem persists. If it does while running the stock mic, then most likely it's internal issues like the one explained above.
Top Galaxy Radio Communications Experts
Ngoro
ADMIN Andrew
ADMIN Andrew
Are you a Galaxy Radio Communication Expert? Answer questions, earn points and help others
