The most likely cause is that YOUR phone must be a ringing destination. If it doesn't RING on the 1st cycle then it does not pass the CID on to the station.
It also depends on which system you are connected to. FIRST be sure you are getting the CID from your carrier.
If you have a TDA system you need a CID daughter board. If it is a TDA-G, then it is built in. There are software options but normally defaults work.
SOURCE: caller id
Some phones are not equiped to pick up call waiting caller id. check the box or look up your model number on the uniden site. The call waiting caller id only shows up on the phone that is in use at the time of the call.
SOURCE: Caller ID display on Panasonic on KX-T7731 telephone set
Pick 2 buttons on the left side keystrip and label them CID-Indication and CID-Selection Then press PROGRAM press the button and dial 96 STORE for the first and 97 STORE for the second. When a call comes in, the Selection button will toggle between the name and the number and if yuu're looking at missed calls, the date and time of the call. When you miss a call, the Indication button will light and you press it to view the Names of missed calls.
Carl
Carl
SOURCE: caller ID/CLIP) not working in Panasonic cordless
Well if the phone has been bought abroad and being used in India you will face this problem. this is because of the format of transmitting the caller id info being different. In USA it is STF and in India it is DTMF. You need a convertor in the phone line which is DTMF to STF. IF you find onw in Delhi pl let me also know.
SOURCE: I have a Panasonic KX-TCA132E
I have a panasonic KX-TCA132Ehandset, have managed unknowling turned the ringer off and now can't turn it on again, please help?
