Was using the oven function, went to check on the food and realized it was off, taught i blew a breaker. Unit dose not come on, as if no power to it.
SOURCE: oven combo, oven works but the micro has no power
The fix for my problem was to remove the oven/microwave combo unit, and press the reset button on the back of the microwave. Oh yeah, and to write a $75 check for a 10 minute service call.
You want to try the fix for yourself? You have to remove all of the face screws holding the unit in place. There are 4 on the microwave front and 6 in the oven, 3 down each side, inside the lip where the door is. You must remove the door to get to the bottom ones. You don't have to remove the screws holding the plastic insert in place between the micro & oven, but you might want to remove the metal lip on the bottom of the oven to help prevent scratches to the cabinet. After that's done, get a helper and pull the unit most of the way out, then rotate a little to the left. That will expose the reset button on the back, right side of the microwave.
The magnetron is defective, cost to repair will probably exceed the price of a new one.
Here
is a tip that will help you to figure out what is wrong with your
Microwave Oven....
Basic Microwave
Oven
Troubleshooting Tips
heatman101
I have the same problem... anyone can share what to do to fix it? I heard 5 beeps on the Conv Bake option but now the machine is totally off. my power outlet is working fine.
