Hey D, f1 can be one of three problems. A stuck key pad,test by pressing all the buttons to see if they all make noise, if one doesn't then that's the stuck one. A bad oven temperature sensor, if it's gone bad it will not send the proper temp reading to the control board. Or it could be a bad control board itself. If nothing is working/changing mode it's most likely the stuck keypad. If you're not comfortable working with electrical components I suggest calling your local repair company to check it out. Hope that helps.
SOURCE: Oven stopped working while cooking a meal
it sounds like it burnt one of your main wires in the back of range. by turning a knob on you are getting a feed back. turn the power off remove back panel take a visual check of your wiring.
SOURCE: have a magic chef oven, f1 display after self cleaning
Your sugestion does not work.I press CLEAR/OFF and power off several times, the F1 error and beeping is continue every 2 minutes. Any other suggestion?
SOURCE: Stove reads "F1" on the display and beeps
Go to www.applianceaid.com/images/ge-built-in-oven-faultcodes
SOURCE: stove works, oven does not
in repairing Kenmores there is a relay well 2 small black an square in the head unit of stove one for stove the other is for oven anyway they go out alot a setback to the kenmore digital controls take upper panel off where controls are look at the green board an you can see them some green some red or blue to tell if one is bad be careful an turn the stove on u will hear the relay click then try oven if you do not hear a click its bad do not i repeat do not touch it while its on
SOURCE: electronic touch pad not working on my oven
Hello beachlady80,
Welcome
You said, It was working fine last night but when you woke up this morning the
display has 3 vertical lines and none of the electronic touch pads
work. The burners on top of the stove still work.
What is the model number and how old is the range ?
Try turning the breaker off for 10 minutes and then on again after this allotted time.
This may reset the system.
Let me know how it works.
Waiting for your answer.
Huuum
Please remember to leave a rating.
Hopefully it will be a solved!
Let me know
Kenmore model numbers are as a example
110.2907864 so to check it out you need the model number and it’s usually down below the oven door. Open the draw and look at the leg for a tag
