SOURCE: wireless printing
The MP830 does not include the ability to do Wireless Network printing. You can however, connect this printer to one of your Windows or Mac PCs and share it on the network, which is wireless, therefore accomplishing the same thing.
1) Install the Drivers and Software that came with your Printer.
2) Go to the Control Panel > Printers & Faxes
3) Right-click your printer and click "Sharing"
4) Choose Share this Printer, and give it a name.
5) You can then on, use the Add Printer Wizard on any other Windows PC and install it by searching for network printers.
Step 1 is the same for Mac
2) Go to System Preferences > Sharing
3) Check the box for Printer Sharing
4) Any Mac on the network can see it!!
5) Added treat: go to http://apple.com/bonjour to install bonjour for Windows, using this software you can print using any Mac printer on any PC
SOURCE: Canon PIXMA MP160 - cannot scan
GET YOUR SOLUTION DIRECTLY FROM CANON. VISIT
www.canon.com/printer/prob3178hgu8/solution
106
SOURCE: Canon Pixma MX310: misfeeds
Hi Paper misfeeds are normally caused by something obstructing the paper path. Look really carefully both above and below the path that the paper takes through the printer. The jammed paper itself can give you a clue about which side the obstruction is on, there wiil often be some sign, such as a bent corner on the page etc. Also check the sliding guides that keep the paper straight, they should be slid in until they are a snug fit with the paper, but not so tight that they stop it from feeding
SOURCE: is a canon Pixma MP160 a wireless printer
Per the information found here, it is not a wireless printer.
If you purchase a wireless print server (similar to a wireless router), you can connect just about any USB printer to it (which would be practically the same as having a wireless printer).
Some wireless print servers that support USB have a maximum of 2 USB ports and 4 or 5 network ports.
The only problem is the additional effort it takes to configure everything to work properly.
Good Luck!
Testimonial: "Thank You, I could not find an answer, and was told many different things. Now I know what to do. Thanks!"
SOURCE: user manual for canon pixma mp210
You may download from here.
http://support-my.canon-asia.com/
