Vacuums Logo
Susan Wilson Posted on May 27, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My dyson dc25 won't turn on we've replaced the on/off switch and it's still not working ??
Steve Pack
Level 3:
  • Dyson Master 7,121 Answers
  • Posted on May 27, 2019
Steve Pack
Dyson Master
Level 3:
Answers
7121
Questions
Helped
2271819
Points
27886
It is either a wiring problem You must check voltage on the switch terminal using a DIM-be careful you could receive a shock sparks tripped breaker or the motor. I would lean toward the power cord it is not uncommon for them to breaker at the handle.
The only parts available are the motor for around
$85.00 and a power cord around $26.00. Motor number and fig number 120V Panasonic Motor SDS1301GND Part Number: DY-91166601 fig 25
Power cord
Power cord Assy Part Number: DY-91426923
fig 38
Cable protector
Cable Protector Part Number: DY-90338201
39
https://www.ereplacementparts.com/dyson-dc25-upright-vacuum-parts
5 Related Answers
Nick Olsen
  • 196 Answers
  • Posted on Jul 28, 2010
SOURCE: whistling noise on dc25 Animal
there may be a small cut in the tube or there is something stuck restricting the suction check all hoses
dumfriesdon
Dyson Solutions Dumfries
  • 102 Answers
  • Posted on Oct 25, 2010
SOURCE: The carpet brush on my
Next to the power switch is another button, this switches the brushbar on and off. The brushbar can be turned off for hard floor surfaces so as not to scratch them
DysonInfo
Manchester Vacs
  • 107 Answers
  • Posted on Dec 20, 2010
SOURCE: Dyson DC25 rotating brush doesnt work
There is a reset button on the side of the brush bar head. Press it.
Anonymous
  • Posted on Jan 25, 2011
SOURCE: My dyson dc25 pipe has lost suction..is something ...
We had the exact same issue. Turns out my wife had inadvertantly sucked up a magnet that was the same size ans the tube. Hold the tube up to a light source. If you cannot see any light, there is something stuck in it. To dislodge the item, stretch out a wire hanger and run it through the tube. It should lislodge the item. Dyson's are great but are very tempermental!
doobla77
Matt Dobing
  • 51 Answers
  • Posted on Jan 26, 2012
SOURCE: how to blow up a mattress with a Dyson dc25
the Dyson upright does not have an exaust outet you can plug a hose into to blow up the mattress, I had the same problem and Dyson told me that basically you can't reverse their vacumme cleaners to blow up mattresses etc.
Can't activate front brush
Hi Sandy, it's Jack at Dyson.
DC25 has a belt engineered to last the lifetime of the machine. It's protected by a sensor which shuts off the brush bar if something jams it. If your brush bar won't rotate it's likely it just need to be reset. Please follow the steps shown in the video I've attached.
Tip: Once you've checked the cleaner head for obstructions and removed any threads or hair from the brush bar, recline the machine into the vacuuming position. Turn it on with the red on/off switch, then press the silver brush control switch twice.
Please note: The brush bar will never rotate when the machine's standing upright, so make sure you recline it down into the normal vacuuming position before testing it.
I'm confident this will resolve the issue, but if you would like further advice after you've tried this, please get in touch with us directly. You can reach our genuine Dyson experts by calling 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA).
Best wishes,
Jack
Dyson Online Customer Support
www.dyson.com
Dyson dc25 off button won't turn off, brush button won't engage brushes
Hi ... did u get this fixed cos mine is the same hve to switch off on the wall?
1helpful
Hi,dyson dc25 overdrive,my brusher's wont go round,i have cleaned the brusher's and filter,loads of suction.the belt is intact and the roller move's feely by hand,could it be the switch
Hi Stephen,
I'm sorry to hear you've had difficulty with your DC25 Overdrive. If the brush bar won't rotate, and you've already checked the cleaner head is free of obstructions, it's likely it just needs resetting.
You might like to take a look at the video below to make sure everything is correct with the machine. Once you've done this, if you turn the machine on, recline it into the vacuuming position, then press the silver brush control switch twice, this should reset the brush bar.
If you'd like any further assistance or advice, please give our Helpline a call on 0800 298 0298. Just to let you know, calls are free from UK landlines, and the Helpline is available from 7am-10pm, 7 days a week.
Best wishes,
Jack
http://www.dyson.com/
Aug 01, 2012 • Vacuums
2helpful
My brush bar wont engage on my dyson dc25. Where do I locate the reset button
I'm sorry to hear you're having difficulties with your DC25. Your cleaner is equipped with a safety device which shuts off the brushbar if it gets tangled with a rug fringe, shoelace etc. After making sure the brushbar is free of threads, hair or other obstructions, you'll be able to reset the cleaner and get the brushbar running again. The easiest way to do this is to follow the steps shown in our guide:
http://www.dyson.com/support/help.asp?article=1156&product=DC25-ALLFLOORS
Please note, the brushbar will never rotate when the cleaner is standing in the upright position, or if you've turned it off using the silver brush control switch located next to the red on/off switch.
By following these steps, you should be able to resolve your issue without further assistance. However, if you've tried this and are still concerned, it's probably best if you get in touch with us directly. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). One of our experts will be happy to run through some troubleshooting over the phone with you recommend the best course of action.
Kind regards,
Jack
Just got a shoelace caught in the brush now brush doesn't spin...dc25 upright..
Your DC25 is equipped with a safety feature which shuts off the brushbar if it becomes tangled with a rug fringe, shoelace, etc. It's easy to reset - please follow the steps shown in our online support guide:
This should get the brushbar running again. Please note the brushbar will never rotate when the cleaner is standing in the upright position, or if you've used the silver switch next to the red on/off switch to turn it off.
If you have any further questions about using or maintaining your Dyson cleaner, please get in touch with us directly - one of our experts will be happy to answer your queries. You can call us free on 08002980298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Dyson Customer Service
1helpful
Dyson is making a higher pitched sound than usual. I do not see blockage in tube, but seems to be when it switches from wand to regular in the curved transition area that I can put my hand over the wand a...
Sorry to hear you're having difficulties with your DC25. Although I note you've mentioned that you can't see a blockage, you might find it helpful to follow these steps from our online guide, just to make sure you haven't missed anything:
http://www.dyson.com/support/help.asp?article=1148&product=DC25-ALLFLOORS
Also, you might find it useful to watch this video guide showing the correct way to remove, wash and replace the filters, to make sure you've fitted them correctly:
http://www.dyson.com/support/help.asp?article=1457&product=DC25-ALLFLOORS
If you've tried this and are still having issues, please get in touch with us directly, so one of our experts can determine the cause of the noise and suggest the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Roller burush is not turning
Sorry to hear you're having a problem with your DC25. Please note, the brushbar never rotates when the cleaner is stood in the upright position, or if you've turned it off using the silver switch next to the red on/off switch.
DC25 is equipped with a safety cutout device which shuts off the brushbar if it becomes tangled with a rug fringe, etc. It's very easy to reset - our online video guide shows you how to do this:
http://www.dyson.co.uk/support/help.asp?article=1984&product=DC25-ALLFLOORS
If you've followed these steps and are still having difficulties, please get in touch with us free on 08002980298 (UK), or 1866MYDYSON (US). One of our experts will be happy to run through some checks over the phone and provide the assistance you need.
Kind regards,
Jack
Brushes won't spin when using the upright mode
Your DC25 is equipped with a safety device which shuts off the brushbar if it gets tangled with a rug fringe, shoelace etc. After making sure the brushbar is free of threads, hair or other obstructions, you'll be able to reset the cleaner and get the brushbar running again. The process is shown in easy-to-follow steps in the video below.
If you need further guidance, please refer to our online support pages:
Please note, the brushbar will never rotate when the cleaner is standing in the upright position, or if you've turned it off manually by using the silver brush control switch located next to the red on/off switch.
By following these steps, you should be able to resolve your issue without further assistance. However, if you've tried this and are still concerned, it's probably best if you get in touch with us directly - you can call us free on 0800 2980298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
[unremark-end]-->
1helpful
The roller on my DC25 will not power up and run when the grey button is pressed.
Sorry to hear you're having difficulties with your DC25. Your cleaner is equipped with a safety device which shuts off the brushbar if it gets tangled with a rug fringe, shoelace etc. After making sure the brushbar is free of threads, hair or other obstructions, you'll be able to reset the cleaner and get the brushbar running again. The easiest way to do this is to follow the steps shown in our guide:
Please note, the brushbar will never rotate when the cleaner is standing in the upright position, or if you've turned it off using the silver switch next to the red on/off switch.
Hopefully this should resolve your issue. However, if you've run through these steps and are still concerned, it's probably best if you get in touch with us directly. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). One of our experts will be happy to run through some troubleshooting over the phone with you and provide the assistance you need.
Kind regards,
Jack
Top Dyson Vacuums Experts
AskDyson
AskDyson
Sean Wright
Sean Wright
xxxxxx xxx
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
