SOURCE: Craftsman Chipper-Shredder Model No. 247.775870
If a small engine wont start its usually one of two problems, its not getting gas, or its not getting spark. easy way to find out if its getting a spark is to remove the plug, put it back back in the connector and just let it hang down while you try to start it. you should see a bright blue spark, if you dont try changing the spark plug. if its getting a spark come back on this site and i'll help you trouble shoot it.
SOURCE: I have Chipper/Shredder model 47321, 10 HP. I have
If you don't see an inline filter then the only filter is a screen in the fuel tank. Sounds like the engine is not getting the fuel it needs. Check the tank and clean as nessesary the screen maybe plugged. If you leave fuel in the tank for long periods of time with out using a fuel stabilizer your carb may need cleaning. Old untreated fuel turns into a varnish like substance. Check your fuel bowl and make sure there is not any dirt in it. You don't mention the engine manufacturer but, mine has the carb adjustment on the bottem of the fuel bowl. I have always used a fuel stabilizer and keep the tank full (filling it with a screened filter) with a added inline filter. In 20 years of my chipper-vacs life never have I had fuel problem.
SOURCE: replacement blades for Troy-Bilt chipper-shredder
The knife kit for the 47042 and 47044 Tomahawk Pro chipper is part number 1772231MA.
There are several for sale on Ebay or from a Murray dealer
SOURCE: Roto-Hoe 550H Chipper Manual request
Yes I have one in perfect condition with prints etc. and the original sale brochure!
SOURCE: craftsman 8.5hp chipper/shredder model 247.775880
here... here's a pdf manual for u
and they also discuss play by play changing the oil for u.
good luck... post if u need more answers....PK
