SOURCE: My Bell & Howell cube slide projector has a
http://cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&item=360183793446
Bell & Howell Cube Slide Projector Gear, New Item condition: New Quantity: More than 10 available Price: US $15.00 Approximately C $15.54 Buy It NowBuy It Now
This is the gear that goes bad on Bell and Howell cube type slide projectors. If you have one of these projectors you can pretty much expect the gear in your machine to go bad. The original gears were made out of an inferior material that was too soft. New old stock gears would be made of the same material and although they have never been used they most likely will fail right away since they are made of the same inferior materal. They were made soft to reduce the mechanical noise when the gear runs. This was told to me by the person who designed them at Bell & Howell. These new replacement gears are made out of Delrin, an excellent material for gears. Delrin is sometimes used to make gears that are normally made of metal. Don’t miss your opportunity to finally fix that old projector or get a spare gear for your working machine while they are available.
Detailed installation instructions will be included with every gear.
SOURCE: I bought a used kodak
The KODAK Carousel 650 was manufactured approximately between 1964 and 1971.
Try removing the tray and pressing the cycle button(s) on the side of the projector. Watch the levers in the cut-out on the top of the projector. The lever closest to the rear of the projector should move back & forth (as you actuate the cycle buttons). The lever toward the front of the projector should extend and push forward (front of the projector) when you push the "forward" button, & extend and push toward the rear in reverse. If you are not seeing these levers move as described, then the chances of your projector needing a repair are likely. The good news: parts are still available. The bad news: You will have to find a factory-trained repair dealer to make the repairs for you.
SOURCE: properly loading the slide tray
If the first slide is visable and consecutive slides are not, the "dark shutter" (a feature that prevents the eye-popping bright white screen when no slide is present) needs adjustment. A fairly easy adjustment for a factory-trained service dealer with the service manual and the correct tools.
SOURCE: slide tray does not advance and slide does not
If the slide tray does not advance or reverse, the slide will not go into the optical "gate" AND the "SELECT" function doesn't work, then chances are that you have a broken mechanism drive belt. The good news is there are all kinds of projector parts still available at: www.micro-tools.com The bad news is that unless you have a service manual and have been into a projector before, this is probably a repair best left to a factory-trained repair dealer.
