Expert
- Posted on Jan 22, 2023
Re: How do I link my Android phone to my 2019 CRV screen?
To link your Android phone to the screen in a 2019 Honda CR-V, you will need to use the car's infotainment system, which is called HondaLink. Here are the steps to link your phone:
- Turn on the ignition of your CR-V and make sure the infotainment system is on.
- On your Android phone, go to the "Settings" menu and enable "Bluetooth."
- On the infotainment system, select "Phone" and then "Settings."
- Select "Add Device" and wait for the system to search for available devices.
- On your Android phone, you should see the CR-V listed as a available device to pair. Select it and enter the passcode provided by the CR-V infotainment system.
- Once the connection is established, you should be able to control your phone's music, make calls and send text messages through the CR-V's infotainment system.
You may refer to the CR-V's owner's manual for specific instructions on how to use the HondaLink system as it may vary depending on the model, trim and region.
