Karthik Muthusamy Posted on May 24, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lightning struck my home. All of my receivers are powering on but are not transmitting any audio or video signals. my DVD player and my Apple TV is also not working. what do i do ?
Jay Plesset
Level 3:
  • Apple Master 2,942 Answers
  • Posted on May 24, 2019
Jay Plesset
Apple Master
Level 3:
Answers
2942
Questions
Helped
668385
Points
9879
Unfortunately, lightning may have damaged your equipment beyond simple fixes. Most likely the sensitive circuits inside are blown, and you may need to replace them all.
5 Related Answers
A
Anonymous
  • Posted on Feb 02, 2008
SOURCE: sony str-dg510
Why dvd sound does not play on sony str-dg510?
Anonymous
  • Posted on May 10, 2008
SOURCE: no HDMI video output from AVR-588 receiver to plasma TV ???
You can also use a digital coax cable (color orange) to go into coax 1 for DVD coax 2 for cable box. Just make sure to set the coax in input settings. The coax cables are a little cheaper than the optical cables and work just as well.
Anonymous
  • 5 Answers
  • Posted on Aug 25, 2008
SOURCE: denon avr5800 with Apple TV
Get a new TV....Seriously
Anonymous
  • 320 Answers
  • Posted on Nov 02, 2008
SOURCE: SONY DVP-NS57P does not display video
If your TV has no input selector but has a video input, the TV probably "hides" the video input between the lowest channel on the tuner and the highest channel. That means if your tuner goes from channel 2 to channel 119, the video input will be between 119 and 2. The best way to see if this is the case is to slect channel 2 and then use the up/down channel selector to go down and see if you find the video input. Let me know if this works!
Anonymous
  • 1077 Answers
  • Posted on Feb 12, 2009
SOURCE: struck by lightning and won't power up
WOW!
Warranty voider there.
Hate to see a $1,000 TV go down the toilet.
If your lucky, you can try checking the fuses inside the TV.
The lightning may have taking out only your power supply board, shopjimmy.com may have replacements for about $100. But, I can't tell you for sure that will fix the problem.
You may have to take to a repair shop to find out for sure.
Good Luck
How do I fix a 50 Plasma TV that seems was struck by lightning
Your probably have power supply damage, but lightning strikes can do major damage in all circuits.
I NEED SONY BRAVIA T32 FULL MANUAL...how to conect to computer and camera
Hello there,
Here is the link to the full manual:
http://support.sony-asia.com.edgesuite.net/consumer/IM/4110401121.pdf
Before connecting your devices...
The signals that enter the TV and connected devices will need to be output in the correct format using the suitable connections. Below are the different types of video connectors. When connecting the TV, use the inputs that are available on your devices that provide the best video performance.
Video performance level Name Aspect Signal transmitted Separate audio connection required arrw.jpg HDMI cnn_hdmi.jpg Picture + Sound No DVI*1 cnn_dvi.jpg Picture Yes
L-AUDIO-R Component video cnn_component.jpg Picture S-Video cnn_s_video.jpg Picture Composite video cnn_composite.jpg Picture RF/Coaxial cnn_coaxial.jpg Picture + Sound No
*1 If the equipment has a DVI jack and not an HDMI jack, connect the DVI jack to the HDMI IN (with HDMI-to-DVI cable and/or adapter jack), and connect the audio jack to the AUDIO IN (L/R) jacks of HDMI IN. (The DVI connector is for video signals only) To enjoy the best visual experience with your system, it is preferable to connect your best devices with the highest quality connections available. For example: your Blu-Ray Disc player or HD Set Top Box with HDMI, followed by your DVD player with Component, then your Video Cassette Recorder with S-video etc.Note: The quality of the picture also strongly depends on the quality of the cable used.
HDMI The High-Definition Multimedia Interface (HDMI) is an all-digital audio/video interface capable of transmitting high definition video and audio signals. HDMI provides an interface between any compatible digital audio/video source, such as a set-top box, a DVD player, a PC, a video game system, or an AV receiver and a compatible digital audio and/or video monitor, such as a digital television (DTV). DVI The Digital Visual Interface is capable of transmitting high definition video, but does not transmit sound. You will need to use the audio connectors of your device (usually Optical/Coaxial digital, or RCA). It is possible to connect an HDMI device to a DVI device using a HDMI to DVI adapter. Component video Component video is an analogue connection. It is capable of transmitting high definition signals. Component does not transmit sound. You will need to use the audio connectors of your device (usually Optical/Coaxial digital, or RCA) S-Video Separate video, abbreviated S-Video and also known as Y/C is an analogue video signal that carries the video data as two separate signals (brightness and colour), unlike composite video which carries the entire set of signals in one signal line. S-Video, as most commonly implemented, carries standard definition video. It does not carry audio on the same cable. Composite video Composite video is an analogue video (no sound) format. This is the connector you should use if you do not have any other connector available, in terms of quality. RF/Coaxial RF Coaxial Cable connection is used for transferring television signals (audio and video) originating from an antenna or cable box to a Television.
Hope this was helpful to you.
Goodluck
Elect_Comp
1helpful
Connected samsung ht x720 (home cinema system 2.1) to v+ box.Cant get picture when playing a DVD.Can hear the sound tough.Thanks
You probably need to change the incoming input signal on your tv.
In other words, your audio is coming directly out from your dvd player, and going directly to the audio power amp.
Your video does the same thing, except it goes to your tv. Your tv has multiple places for "incoming" signals to hook in to it. Take a look at where you're hooking your video in - the input should be marked ... something like "Component 1" "Component 2" "HDMI 1" "HDMI 2" ... something like that.
On your remove, there will be a button that says, "Input." When you push this, you will see that your TV brings up an input selection window. Pressing the "input" button on your remote should scroll through the ports on the tv. Briefly pause on each input selection to see if it begins receiving a video signal from your DVD player.
Denon receiver just struck by lightning.
Any time a unit is hit by lightning, it is usually a total loss. While the initial problem may be fixable, other components have been stressed and are likely to fail. Most shops won't work on these units because of the likelyhood of continual failures. Warranties won't be given or the repairs. In your specific case, the switching IC has been damaged and needs to be replaced as well as the surround processing section. This is best handled as an insurance claim for replacement.
Dan
1helpful
I just purchased a denon avr-1610 receiver and I cannot get picture back to my tv through the hdmi. I have a starchoice dvr which is dvi to hdmi, I come out of my satelite into sat/cab then out of my denon...
One possible reason is the HDCP (copy-prevention)-encoded signal from the DVR, which will transmits through to one device (the receiver) but not to a second (the TV). As an experiment and a possible solution, try reconnecting the HDMI cable from the DVR directly to the TV (provided you have an extra HDMI input on it), and using the component-video or S-video plus either digital or analog audio outputs to connect your DVR to the receiver. If this works, I think that the HDCP is the problem and this is the only solution.
It may be a little inconvenient to remember to switch inputs on the TV as well as the receiver, but you could probably program your remote with a macro to do both. The component video (or, more likely, the S-video) is also the best possible video signal you can use for dubbing to any DVD recorders, if you have one connected to the same receiver. You can still keep the HDMI connected from your PS3 (or other BD/DVD) player to the receiver, and from there to the TV, since that does seem to work -- if you don't mind turning on the receiver every time you want to watch a BD or DVD. My recommendation, however, is to connect all your video signals directly to the TV via HDMI or component, and use the receiver only for audio, or for switching of lower-level video signals like S-video that you can use for dubbing. That way you can always check the DVR or BD or DVD quickly without powering up your receiver, which takes a few seconds and much more power.
2answers
Receiver will transmit t.v. sound but no picture
Maybe the video portion of your receiver was fried by the lightning. The good news is, you don't need it!
I run all my video sources (sattelite, xbox and dvd player) to my TV with hdmi cables, and a single toslink(optical) from the televison to my 5.1 home theatre receiver. it sounds great and I only use a single input of the receiver for all my video.
If your setup does not have toslink themn use coaxial digital. it is also one wire and probably is indistinguishable in sound quality.
for future, run the power for all your electronics through a UPS or fancy surge supressor to protect them from bad power (and lightning)
1helpful
2answers
No sound unless VIDEO signal is plugged into receiver
Connect the DVD player audio with digital coax into the digital audio connection as you described and the DVD video directly to the TV. Now switch the input mode on the receiver to DVD. Then switch the video output mode on the TV to correspond to the input you plugged into. Any source in 5.1 dolby digital or dts should now work properly and have picture too.
Cannot hear DVD through the DVD receiver port
I had to turn on the TV first then the receiver and DVD player to see the video of the DVD.
1helpful
2answers
Wireless Headphone not working with my portable DVD player
Firstly, make sure your DVD have built-in IR wireless module so that your headphone can receive the audio signal from your DVD player.
Second, it should be clear which frequency transmitted from your DVD player. Generally speaking, there are two frequency of IR transmitter.One is 2.3MHz/2.8MHz. another is 3.2MHz/3.87MHz. Only emission frequency same as receiver can receive the audio signal.
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
