F77 is the Ceramic Control valve - the fault usually means the control valve either can not switch positions or can not find the position requested - Not to difficult but probably better off to have a service tech to replace it
How do you fix it if you can’t find a technician that can come out soon?
SOURCE: Miele CVA4085 coffee machine
no water in tank or water valve close thanks for using fixya pierre
SOURCE: I have a Miele cva2650
This refers to the water heater no longer heating. There is no user solution, you'll need to call for service.
SOURCE: Says in the display Fault 10 and Fault 17. CVA
I just switched machine off for a few hours and when started, it was OK
SOURCE: Miele coffee machine shows
Hello Wiesiek1,
The water system fault means that there is too much water on the bottom drip pan and it has tripped the sensor at the bottom of the machine. Usually removing the bottom grate where the cups sit and taking some paper towels and soaking up the water/spillage will fix this problem
SOURCE: display message - brewunit block - can not undo to
YOu must turn the machine off...hold both the small coffee and hot water button...tunr the machine on to light...let go of the buttons..then hold in the large coffee button for a few secinds andletgo ..if that doesn't work hold in the medium coffee button for a few seconds and letgo..that shouldreset the brew unit.
good luck
