Codes are never displayed on the radio, so not sure what you are reading? There are three ways to get the radio code.
https://www.fixya.com/support/r29874205-need_vehicle_radio_code
[HELP] Need radio code for 2003 Holden Astra - Austech
austech.info
https://www.austech.info > showthread.php > 113459-...
Jun 2, 2018 - 1. Switch on ignition. 2. Switch on the radio, if turned off. 3. The display shows 'CODE'. 4. Press and hold AS button 8, until a
[HELP] Need radio code for 2002 Holden Astra
Oct 23, 2014
Radio code needed for 2003 holden astra
Feb 28, 2017
Code for Holden Astra Radio... PLZZ
Nov 27, 2014
Holden astra radio code
May 17, 2018
More results from www.austech.info
how to enter radio code - Holden Technical Talk - Fastlane
fastlane.com.au
https://fastlane.com.au > forum > postst26977_how-to...
Say your code is 4567. You press the AS button until your hear a beep, then press the no. 1 button 4 times, the no. 2 button 5 times, the ...
How do you input radio code for Holden astra?
Answers
https://www.answers.com > Auto > Auto Parts
Oct 26, 2022 - Press the AS button and hold depressed while turning the radio on. (after 3 secs you should hear a beep. Release the AS button. The display ...
SOURCE: Radio code not working for 6000 cd rds eon
look in boot left hand side and you will with any luck find the radio code stuck on a sticker
SOURCE: blaupunkt radio security code not working on my Holden Astra
First make sure that the code has not been noted somewhere within the car (underneath the ash tray, glove box , rear of sun visor etc)
To see if your code is available here for free then the radio will have to be removed from the dashboard (and if you are lucky, someone may have written the code on the casing ) .
If not then POST ANOTHER QUESTION
quoting the radio MAKE+MODEL plus ALL the LETTERS+NUMBERS on ANY LABELS ,BARCODES or STAMPED IN THE METAL CASING
note: Unfortunately not all radios can be decoded using the Serial Number
If not then try your Main Dealer ...........or take it into a Decode Service who will plug in a laptop to read/recode the memory chip (EEPROM). This takes a few minutes and shouldn`t be too expensive
Here is a video showing how to remove your radio from the dashboard. A pair of extractors are required (available from Ebay , etc) but these can be made from 2 pieces of bent, wire coat-hanger or 4 small drills(using the blunt end) or 4 small Allen Keys or 4 small screwdrivers or 4 nails or even 4 darts.
An assistant is useful to pull the radio out whilst you are releasing the 4 securing clips
http://www.fitaudio.com/videos/din_keys_guide/video_din_size.html
SOURCE: code for cd player in holden astra
quoting the radio
THE METAL CASING
Also quote the MAKE of CAR
Serial Number
Otherwise try your Main Dealer ...........or take it into a
SOURCE: 2002 Holden Astra 'Blaupunkt - CD player' MANUALS on the net?
This is a link to Blaupunkt for manuals, I don't see your paticular "model" though. See if you can locate it.
http://www.blaupunkt.com/us/downloads_1.asp
SOURCE: How do I enter the radio pin code (which I have)
press and hold AS button for a couple of seconds till beep is heard and CODE----
is displayed in the display
use the preset button 1to get 1st number then preset button 2 to get second number etc.... until all 4 digits are entered then press and hold AS button again until beep and radio should start working
