J
Johnny Wesson Posted on May 23, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Technics cassette deck RS-M7 makes loud buzzing sound when pressing play, ffw, rec, or rew. Both meters also peak out when this happens.
Franco Dosil
Level 3:
Top Expert:
  • Technics Master 10,542 Answers
  • Posted on May 23, 2019
Franco Dosil
Technics Master
Level 3:
Top Expert:
Answers
10542
Questions
0
Helped
377326
Points
178965
Hello Johnny, for what you comment, the noise Leo produces the Rec-Play key inside your RS-M7
Take out the lid and you'll find on the main plate, a long piece of metal, that on the Rec-Play key
Use some contact cleaner or a couple of drops of DW-40 and apply them by one of the ends of the key,
With the equipment off, put a cassette and press the keys Rec and Play, then Stop and repeat the sequence several times, you will see that the key moves a slide, where you put the cleaner
Then connect again, turn on Play and it should work fine
If not, consult a specialized technical service
I hope I can solve the problem
Greetings Franco Dosil
Hola Johnny, por lo que comentas, el ruido leo produce la llave Rec-Play dentro de tu RS-M7
S?cale la tapa y vas a encontrar en la placa principal, una pieza met?lica larga, esa en la llave Rec-Play
Utiliza alg?n limpiador de contactos o un par de gotas de DW-40 y aplicarlas por alguno de los extremos de la llave,
Con el equipo apagado, pon un cassette y presiona las teclas Rec y Play, luego Stop y repites la secuencia varias veces, veras que en la llave se desplaza una corredera, donde haz puesto el limpiador
Luego conecta nuevamente , prende pon Play y deber?a funcionar bien
Sino es as?,consulta un servicio t?cnico especializado
Espero pueda resolver el problema
Saludos Franco Dosil
5 Related Answers
Anonymous
  • 189 Answers
  • Posted on Jan 09, 2008
SOURCE: connection between CD, EQ, SP technics
Each unit (the EQ and the Processor) should have left/right in/out rca jacks as well as L/R tape in/outs. The EQ or processor use the receiver's tape loop and then provide a tape loop to replace the one they've used on the receiver.
You plug the first unit (let's say the Sound Processor into your receiver/amp as if it were a tape deck (Processor's outs connect to reciever's tape ins (play) while the Processor's ins connect to the receiver's tape outs (record).
Then you chain the EQ off the Processor in the same way (EQ outs connect to Processor's tape ins (play) and EQ ins connect to the Processor's tape outs (record).
Last you connect the tape deck to the EQ as follows. Tape deck outs connect to EQ's tape ins (play) and the tape deck ins connect to the EQ's outs (record).
This will put both the Sound Processor and the EQ in the receiver's tape loop. In order to have all the receiver's source signals routed through them you may have to engage a Tape Monitor switch or button somwhere on your amp which will route the tape loop to your speakers.
Anonymous
  • 1512 Answers
  • Posted on Jan 26, 2008
SOURCE: Remote control for Technics RS TR 272 Dual Cassette Deck
a system remote is the only option for you here. The deck does not have its own remote receiver. Sorry to break the bad news to you.
Grubhead
Grubhead
  • 5755 Answers
  • Posted on Aug 06, 2009
SOURCE: Tascam 122MKII - press play no sound, meters don't move
Look for small leaver or any contact switches. They might have become bent out of shape or broken, or have dirt in them, cutting off the sound. Also check the leads coming from the head, they might have become detached or at least you can trace where they join the PC board. If you touch where they join you should get a buzz on either channel.
Grubhead
Grubhead
  • 5755 Answers
  • Posted on Nov 02, 2009
SOURCE: Technics Tape Deck RS-M227X. VU needles jump to the maximum right
More than likely the pre-amp IC has failed! Trace the wires from the VU meters back they should locate the source of the problem. Remember it will be something common to both channels!
skywavebe
Sam Palermo
  • 1267 Answers
  • Posted on Oct 17, 2012
SOURCE: Technics RS-TR272 dual cassette deck
Ahh, Another Dual cassette deck. These are typically not worth a repair charge. I went looking for a service manual but Hi Fi Engine did not have one but they had a Owners Manual. Any unit that has a specification as to wow and flutter starting new at .18% was never made to be a long lasting deck of any quality. I don't like to be negative about people equipment but you might be better off getting a better deck from the start. If you think it is worth the repair, then send it to someone but I don't think you will want to sink $100 into a unit like this.
I am not saying it is unrepairable but that with what you come out in the end you could have made a better choice for a deck to buy.
It is probably a bad solder joint or bad capacitor on the circuit board.
I am in Chicago and would look at it for you if you want.
My technics cassette deck tr575 everything seems to work all the functions all the buttons but when I put a cassette tape in the unit I see no responce on the db meter... Everything is functioning on
There are 2 long switches, maybe 4" long, called record/play switches. These can certainly cause this. Try cleaning them with the power unplugged. You would turn the cassette deck on end, so the switches are vertical. Use LPS-1 or LPS-2, and spray a very small amount in the end. Work the switch back and forth and see if that helps. Good luck.
How to tape from one deck to another?
Press the Dubbing A to B button. Put your blank tape in deck B. Press REC/PAUSE on deck B. Press Play on deck A
My tape decks buzz but when i touch it with my bare finger it goes away
It can be a bad ground inside the deck or broken solder joint. I have fixed this case often but can not tell you exactly the problem unless I see the unit.
I can't find the manual to my Technics RS-TR272 Stereo Cassette Deck. How do you tape something on one cassette to another?
Place the tape you want to record into the left deck, Then the blank tape into the right deck. Press play on the left deck and record on the right deck.
It may be opposite depending on which side your recording deck is on.
Which ever deck has record, place blank cassette into that one and the cassette you want to copy into the other deck.
Hope this helps and please rate thanks
1helpful
Need to find user manual. I have a problem in recording a tape. I put in deck1 --- cassette to be recorded in deck2 new cassette start play on deck1 ... turn on record and play in deck2 as...
for a start your title says "Problem with the Technics RS-TR272 Single Cassette Deck"
So is it a single or double?
i'm assuming it's a double,right only one of the decks records so put the blank tape into it make sure the tabs on the top of the tape haven't been broke or you'll need to cover the holes with the labels you get with the tape.
put the tape with the music on it, in the other deck rewind them both then press "sync rec" & they should both set off.
The door is not opening easily and tape runs for approx.2 sec. during playback then right hand reel table stops and the deck switches to stop. FFW/REW is OK.
i have same problem with 2 sec playback then stop on technics rs tr232. need advice and enlightenment so repair guy doesn't rip me off.
4helpful
I need to know how to record 1 tape onto another tape on a Technics rs tr-575 dual cassette deck
press the synchro start button, the tape deck should now go to REC PAUSE, press the SPEED button till you get the required recording speed then press the synchro start again and it should start to record from deck 1 to deck 2.
make sure the tabs at the top of the tape you want to record on are intact,
if not just put a bit of sticky tape over holes.
hope this helps?
2answers
Problem with deck B on Pioneer CT-W205R
Better tape decks, like Pioneer, may use a different mechanism for record/play than FF & REW. So it sounds like a belt or mechanical link for the REC/PLAY has failed.
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
