Randy McCoy Posted on May 22, 2019
Can’t find Sirius radio in my lincoln - Sirius Audio Players & Recorders
Need radio code for Megane coup 2002. is it possible to get it with the VIN number?
Is this a satellite radio subscription code? if so, for my Lincoln, all I had to do is press and hold the Sirius radio mode button on the dash and it appeared on the display. If not, I'll shut up now. :) good luck.
HOW DO I CONNECT MY KENWOOD KDC-BT555U RADIO TO SIRIUS
If it Sirius capable, get the radio's Sirius satellite ESN, (electronic serial number), from your radio and call Sirius satellite radio and they will tell you what to do. I don't know how to get this number from your unit but in my Lincoln, all I had to do was push and hold the Sirius button on the dash with the radio on and it popped up on the display. Your instruction manual should tell you how to do it. If it isn't compatible, you'll have to buy a Sirius receiver and have it activated with them. Good luck.
2009 f250 tried to activate Sirius radio and stereo says satfault. What can I do?
It's likely that the truck didn't come equipped with the satellite tuner, in which case you'd have to buy an aftermarket kit like this one: http://www.tss-radio.com/isimple-factory-ipod-sirius-integration-for-ford-lincoln-mercury-vehicles-fd1.html
2answers
My 2008 ford focus sirius radio stopped working. sirius tried to reprogram, but it didn't work
Did Sirius resend a signal? If it is displaying their number it is likely that your subscription needs to be updated. The fact that it displays their info means it is likely receiving a signal. If it said "no tuner" or nothing at all, it would likely be the tuner. You can resend a signal online here:
http://www.siriusxm.com/activationhelp
If that does not work, replacement kits are available here:
http://www.tss-radio.com/products/isimple-factory-ipod-and-sirius-integration-for-ford-lincoln-mercury-vehicles-1
1helpful
Sirius radio reset on dodge ram 2008
I have the same problem. When Sirius sent me a new "update" signal, I lost more channels. They don't have any idea. Did you figure out how to reset?
2answers
Sirius Radio Invalid Channel message
1) Do you have a Sirius account?
2) Have you called Sirius and given the serial number of that receiver?
Those are the first two things you have to do to get a Sirius receiver working. (The original owner could have changed his account to use his new receiver, if he has one.) Go to http://www.sirius.com/install - the "activate" part - for details.
Top Sirius Audio Players & Recorders Experts
John
John
ZJ Limited
ZJ Limited
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
