Question about Lands Phones
My employer has a AASTRA 9110 I want to set voicemail rings on my phone. Please advise.
6ya staff
SOURCE:
StuartB
Stuart
  • 807 Answers
SOURCE: aastra telecom 9316 cw
Yes:
http://www.aastratelecom.com/cps/rde/xchg/SID-3D8CCB73-12A0DEC9/03/hs.xsl/21564.htm#dl_instructions
Look at the bottom of page.
Posted on Mar 21, 2008
Anonymous
SOURCE: I need to change the number of rings before phone goes to voicemail
First, call your voice mail. After the messages you will be given a menu to follow. On the Sony Ericsson W350 I went to Personal Options (4) then to Administrative Options (2) and finally Prompt Level (3). After reaching Prompt Level you have the option to shorten or extend the number of rings. At this point I chose to shorten the prompt and then I exitted the system.
Posted on Apr 13, 2009
Anonymous
  • 5 Answers
SOURCE: nokia 6210 voicemail only rings 5 times before
go to your tone setting and then you wil see it says sumthing about ringing once, assending ect, change that to assending!
Posted on Jun 10, 2009
Anonymous
  • 18 Answers
SOURCE: My phone on our Norstar system rings & rings
Fress F985 u will get voicemail DN. Note down ur voice mail DN.
Go to programming of Norstar which will be F**266344 password will be 266344.
Dispaly shows u terminal and extensions.
press show
then next display will show u capabilities.
Press show then next display will show u FWD no answer.Press show then change put the voicemail Dn which u had written then next.
Now call will go to ur voicemail provided u have ur own presonal mailbox. If it is not there u will have to createe it otherwise it will go to general delivery mailbox.
Hope it will be helpful for u.
Thanks.
Posted on Jul 12, 2009
professio101
Robert Engel
  • 158 Answers
SOURCE: Incoming calls ring 3 times
Your voicemail thinks that it is ringing six times. The time that it takes to transfer to the extensions counts. Whiloe it seems that there is a lapse the system actually is using enough time to ring six times total. If you need longer ring time at the extension, take in account the transfer time and set it to pick up after 8 or 9 rings. It will actually only ring six. You just have to trick the system a little.
Posted on Jul 22, 2009
The red light on my Aastra phone 9133i does not blink when I have a voicemail message
Phone your provider and ask them to turn on the indicator light. If you hear beep beep beep when you have a message they have it set wrong. Tell them you have a red light on your phone. They just set it incorrectly . Happens all the time hope this helps
Oct 24, 2013 | Aastra Telecom 9116 Corded Phone
Bell message set
You have unheard messages on the voicemail system provided by your telephone company. This system takes messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Jun 14, 2013 | Aastra Telecom Powertouch/Vista 390 Corded...
Aastra 9110 message light doesn't light
were you able to get this working? hat did you have to do?
Dec 07, 2012 | Aastra Telecom Aastra 9110 Single Line...
My answering service picks up after 3 rings....how do i extend the answer time to 6 rings or so?? I have the 9417 CW
Ask your provider to change your voicemail to pick up in36 seconds instead of 18. Each ring is 6 seconds. Hope this helps
Sep 24, 2011 | Aastra Telecom Aastra 9417 CW Corded Phone
How to I forward a number from one phone to another?
If your phone company provides the service, you should have a code to enter. If YOUR telephone switch is doing the forwarding, you will also have a code to enter.
Basically, you enter the code, then dial the number and hang up. To unforward, you dial a similar code, and hang up the phone.
May 06, 2010 | Aastra Telecom Aastra 9110 Single Line...
HOW do I increase the number of rings before the answering service clicks in?
Depends on what cellphone and provider you have. Smart phones(Windows Mobile anyways) have a setting in them that lets you change it. Also try calling your voicemail and going though the prompts. there maybe a setting in that.
Aug 12, 2009 | GE Nortel Aastra M9316CW - Black- Phone...
How to set up voicemail
If you have an active voicemail... but have never activated it:
The default password is 0 0 0 0 (four - zero's)
The voicemail will talk you right through setting up voicemail, after the set up you can press 8 anytime you are in the voicemail to make changes to your account.
Feb 11, 2009 | NorStar Nortel Aastra B0240402 Phone Ash...
Aastra telecom 9316 cw
Yes:
Mar 21, 2008 | Aastra Telecom Aastra 9316 CW Corded Phone
Aastra 9110 Single Line Corded
Press the setup key and use the down,up,across arrows on the upper of the set below the window to find the date and time. Let me know if you get it done.
Feb 18, 2008 | Aastra Telecom Aastra 9110 Single Line...
Lands Phones Logo
Top Lands Phones Experts
Ekse
Marvin
Marvin
Are you a Lands Phone Expert? Answer questions, earn points and help others
