SOURCE: ricoh aficio mp2000
Turn off the power for at least 5 to 10 minutes and then on. That code means that the main motor is locked.
SOURCE: error code sc500
Your main motor is hard to turn.. Check your Drum unit. Pull it out then on the back side you'll find a small agitator gear then tried to turn it. If it doesn't rotate then you might have to change its paddle gears, idle gear or that development sleeve is stuck. Hope it helps.
SOURCE: Ricoh SP C811DN error sc549
unplug printer, wait minute, plug in, should reset.
check Ricoh website to trouble shoot if does not reset.
SOURCE: I have tried resetting ricoh aficio 161 showing
Main motor error SC 500 The main motor does not reach its operation speed within 0.7 second, or the main motor remains out of its operation speed for 0.7 second after reaching the operation speed. ?? Overload ?? Defective main motor
Testimonial: "Thank you very much! Really appreciate your response :)"
