SOURCE: water will only dispense out of the frother.
It could be several soutions to this problem. First of all, try to clean the sieve in the brew unit, it may be clogged. Take out the tray, in between the 2 brown "lips" inside you can put your finger up and clean out all the old coffeegrounds stuck up there. Then put everything back in place and run a Rinse machine operation.
If this is not helping, listen out when you start up the machine; You should hear that the valve is turning 3 times, if it doesn`t it can be a problem with this valve not opening in right position. Then all the water would go out in the tray, and not into the brew unit. That maybe can be solved by changing this Multi ceramic valve or the Main Electronic board. Then it`s a job for a sertified Jura technician.
SOURCE: Machine grinds coffee, cycles the grinds, tamps,
Remove the brew unit and check for blockage in the shower screen, then try to brew coffee if same result machine might need to be descaled.
SOURCE: All water directed to Frother/ Water nozzle on Impressa C%
The Multivalve seems to be stuck. When you start up the machine you should hear the multivalve turning 2 times, if it`s silent, the valve is defective. This valve is important to guide the water in the right direction. Contact your servicedealer and let them have a look. There`s also a small chance that the electronic board are sending wrong or no signals to the valve
SOURCE: water not pumping out of coffee machine
It seems that the coffee solenoid valve is blocked or broken. Cofffe solenoid valve is the valve which open to deliver the water after the pump to the coffee shower.
SOURCE: The water pours out the sides when I make
the gasket needs to be replaced. I just had to replace mine. http://www.krupsonlinestore.com/product_detail.asp?T1=KRW+MS-620342&MENU=&SELECT=&SKW=xp4030
