SOURCE: Opening the top of front load LG washer
to get your lid of the washer there are 2/3 screws at the back right under the lip of the lid once you have taken the lid of u will see the top of the soap drawer u can sometimes get into these by undoing the clips on either side of the soap drawer if u cant do it that way only other way is to make sure your soap drawer is closed properly and hit it hard at the front it should dislodge more than likely your conditioner drawer
SOURCE: Neptune front load washer buttons wont work
I tried un pluging the machine for few hours and it will work for 3-4 load and then it will lock up again
SOURCE: Whirlpool 9400 Front Loader Washer Control Button Locked
find button with lock emblem beside it hold 3-5 secs
if you are mechanical and are not afraid of small wires you can try this. I had the exact same problem on my machine. i very slowly diasssembled the machine. not hard to do. removed the top. unscrews from the back and slides to the back to come off. remove the door. unsnap the plastic plate that goes around the door.it is held on by small snap clip that pop off if you use a small flat screw driver to pry it out. remove detergent tray. and screws that attach it to the inner box. now the hard part. remove the face plate. it unsnaps similar to large door plate.very carefully unclip the circuit boards. they are held in by plastic clips around the outside and white plastic clips in the middle. you must gently pry up and release these clips one at a time. a second person is helpful, so are small needle nose pliers. clean both circuit boards very gently with isopropyl alcohol and qtips. mositen the qtips and clean every inch of the boards. be very careful not to bend or crack anything. you must get all the yellowish flux and any other corrosion growing on the board off. there is one more board that must be cleaned. the power supply board. it is mounted on the top right side near where the face plate wire come through. this is not hard to remove it is held in by small clips. the tricky part is the wires. they are all designed so they cannot be plugged in incorrectly but i have seen what people are capable of. make a map. number them with a sharpie so you know where they go. remove this board and clean it the same way. this on will probably be the worst offender. i cleaned all the boards reassembled and it works like new. below the door is a panel that should also be removed. there is a removable drain filter that should be cleaned out. i found pens and toys in mine. the machine could not pump out the water fast enough and would shut down and trigger f70 and f 20 codes.
SOURCE: Door locked on compact Whirlpool front-load washer
This worked for me. I turned off the washer and hit the area on the washer directly to the right of the door handle (not hard enough to break something or cause a dent). It popped right open.
