Braun Tassimo TA1200 Espresso Machine Logo
Posted on Aug 07, 2009
All the lights are flashing on my Braun Tassimo TA1200 and will not make coffee
Anonymous
Level 1:
New Friend:
  • Contributor 5 Answers
  • Posted on Dec 24, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
5
Questions
0
Helped
29957
Points
27
Several possibilities: (1) No water in tank.
(2) Tank not inserted properly. Try removing tank and then replacing it, making sure that the hook-tab at the back of the tassimo body engages the matching slot at the front of the tank.
(3) Tank not seated properly. Try pressing down on the tank and twisting left or right. If this stops the blinking and allows your drink to brew, at least you know where the problem is. If you have to do this all the time, consider exchanging the unit.
(4) The lights will all also blink if there is residue (coffee, milk, etc) on the bar code reader window. The residue is usually plainly visible. The bar code reader window is a horizontal rectangel directly under where the bar code of the T-Disc sits in the Tassimo. To fix this, just wipe the window clean (no need to scrub), close the lid again and check for blinking.
  • Anonymous Mar 02, 2012
    What if my hook-tab broke off and super glue just isn't strong enough...
Louise McLaren
Level 1:
New Friend:
  • Posted on Jan 20, 2015
Louise McLaren
Contributor
Level 1:
New Friend:
Answers
5
Questions
0
Helped
36054
Points
12
I had this problem, all lights flashing and nothing happening. Although the float in the water tank seemed OK popping up and down, I took it out and broke it open to find the magnet had corroded due to water leaking in. I placed one of my kids' magnets over the part of the machine that lined up with where the float would be and the lights stopped flashing! So I took a hammer to the magnet so I had just a small piece and wedged it in between the water tank and machine. Works perfect now. You could fashion something else or replace the float if you can get hold of one but this way works fine. I refill my tank using a jug so I don't have to fiddle about with the magnet when trying to put the tank back.
  • anitaroberts
    anitaroberts Jun 24, 2017
    I cannot believe it but I had a small magnet but didn't know where to actually put it...frustrated I t fell out of my hand and stuck to the side where the water tank goes in, lights stopped blinking machine started heating and we ready to brew @ it did..........Thank you so much for this post!!
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 07, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
22512
Points
Tassimo coffee t disc was put in improper & coffee went everywhere now my machine wont work
Older Braun Tassimo lights flashing. Not working.
If all the indicator lights are flashing after you've initialized your machine, reset it by turning it off and then on. If there's no disk in the brewing mechanism, all the indicator lights will flash.Sep 5, 2020
Braun Tassimo Coffee Maker Troubleshooting ' Hunker
Videos as well, or time for a new one?
https://www.google.com/search?q=Braun+Tassimo+lights+flashing
Problem with Braun Tassimo Espresso Machine/Coffee Maker: all the lights are flashing and does not working. bar code reader are clean, somehow the water is not going throw on the machine
the unit needs to be descaled. order the clean tablets from Tassimo and follow the steps as printed in your owners manual as an alternative you can use any good quality espresso cleaner but DO NOT USE VINEGAR as this could damage the boiler...
When I turn on my Tassimo Coffee maker, the refill water light just flashes, and it won't brew. What can I do? I have tried re-inserting the water tank, cleaning off the barcode sensor, twisting the tank...
I ran into the same problem myself. One possibility is this: Follow this sequence: 1) With the top up and the disk NOT engaged, turn the main power on. 2) Put the disk in and lock the top down. At this time, the cup logo shouls flash once and stay on. 3) Push the large round button once and the cup logo will flash and the brewing should start.
I had a few things out of sequence at first and it was frustrating me as well. I hope this helps!!
I have two flashing red lights on my tassimo. Nothing I have tried works.
Hi the top light is orange but the bottom light is flashing red and only a bit of water will come out then it stops
4helpful
Braun Tassimo - plug it in and no lights
have you switched it on on the back of the tassimo
4helpful
Wont heat or make coffee lights keep blinking
All lights flashing -
The machine is not prepared for use. Check water level, T-DISC.
Also try this link for the user manual:
http://www.scribd.com/doc/2421389/Braun-Tassimo-User-Guide
Another thing, try unplugging the machine; wait 5 minutes and plug back in.
Refer to the user guide for further diagnostics.
If you're still having problems contact customer support - number in user guide.
Thanks for trying Fixya.com
Mike...
7helpful
Braun Tassimo Coffee maker quit working
Hmm if not in covered try
http://rapidshare.com/files/238159116/Braun_Tassimo_3107_Disassembly.pdf.html?killcode=397312781122638452
23helpful
3answers
Braun Tassimo 3107 lost instructions
where do i get instructions on how to use the braun tassimo 3107
4helpful
Manual for Braun Tassimo TA1400 CoffeeMaker.
I found a website under Braun that had the operating manual in pdf.
Top Braun Coffee Makers & Espresso Machines Experts
Sean Wright
Sean Wright
Sulejman Sulejmani
Sulejman Sulejmani
Are you a Braun Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
