Question about LG Computers & Internet
Hello Can I fix a movable wifi on the LG 2104 DVR to be connected to the internet router wireless instead of a cable?
    Master:
  • 625 Answers
I don't know. when i have vrouter questions, i call my internet service and talk to techs. they help at no charge.
Posted on May 21, 2019
6ya staff
SOURCE:
Pierre Laplante
  • 2042 Answers
SOURCE: wireless router
delete and retry to enter instalation cd hope work cheers
Posted on Jan 15, 2008
bpcs
Jim Bruner
  • 112 Answers
SOURCE: Linksys Wireless WRT54G vs. WET54G
For what it is worth, I fhave found streaming video does not function well using a wireless connection. The options of multipale routers will work as long as you configure them as to not have conflicting IP address assignment's via DHCP, and the routers do not have matching IP address's. Never fear all is possible with paticence. BPCS
Posted on Jan 20, 2008
Anonymous
SOURCE: Problem with wireless connectivity for LG-E500
i want drivers for LG500E i changed vista with XP
Posted on Aug 11, 2008
Anonymous
  • 12 Answers
SOURCE: Problem with netgear super g router
Here's sort of a checklist of things to consider:
1. First of all, connect the computer directly to the cable modem. Make certain that your ISP (Comcast) is providing internet service. Modems (DSL, cable) typically have a web page (HTML document output format) interface through which you can connect with your favorite HTTP client (that is, browser), such as MS Internet Explorer or Mozilla Firefox. You can always connect to that if your computer has been given an IP address: you would look for the device you are connected to (modem, router) as the "gateway IP address" (for modems, it might be a 10.0.0.x IP number or something like that; for routers, it might be a private LAN address of 192.168.x.x or 172.16.x.x or something like that). Type in the gateway IP address: if it unsecured, you will see the interface immediately with gettable (status) and settable (configurable) form controls; if it requires authentication, you must enter a username/password combination to gain access to the interface. The default username/passwords are provided in the user guides of the device from the manufacturer.
2. Once you are sure the modem is providing service and that you have configured it properly, then remove the connection to the computer and connect the router. Check that all the lights of the router illuminate properly after startup.
3. Now connect BY ETHERNET (Cat 5 unshieled twisted pair) cable your computer to the one of the slots to the router. We'll go wireless later. Make sure that you are now getting internet service through the router while connected to it with the Ethernet cable. Make sure that you are talking to the router through its web interface. Again, look at your internet settings (find the gateway IP address), and enter that IP address into your browser. You will be challenged for authentication: use the router's default authentication (usually the user name is "admin" and the password is also "admin" or maybe a number sequence like "123456", I don't have your super G model number) and then enter the Interface. Perhaps you need to make special settings for the type of broadband: VCI and VCP values and protocol for the WAN side. You might need to learn these from Comcast's support (by phone or by web site).
Alternatively, rather than us the browser interface to your router, Netgear may provide a CD install disk which contains an application you run to directly manage your router device. It will configure it and also set it up for wireless (see next step).
When you see web pages (such as Google, Yahoo, even Comcast's) through your router, then you are ready to configure the wireless part.
4. While still connected to the router's web page interface in admin user mode, look for the wireless part. You need to set an SSID (don't use the default...create a name you can recognize). This SSID is broadcast to the wireless and you will identify it when opening your computer's wireless adapter. Set an authentication mode as well, so that only you and other can connect to your wireless and no one else (prevents unsecured connections, and turning your wireless into an open "hotspot"). Use WPA or WPA2 (not WEP) if you have it, and you will be given or asked to create a key which is probably a series of numbers and the letters A through F (a long hexadecimal number). Write down the authenticatin type (WPA or WPA2 with AES or TKIP and the key value) and then write this information in for the wireless setup of all computers wishing to connect to the router. You can create this also if Netgear provides an interface (by an CD install disk) for your computer: it may tell you to insert a USB drive to copy information that you would then use to configure all computers that will use the wireless, since it will setup a network configuration that includes the authentication key.
For specific information about how to configure the wireless adapter for router connection, you would need to give the OS you are using (WinXP? Win Vista? MacOS? Linux?)
In future posts, or messages to me, please as a rule provide as much information as possible about ALL devices, namely make AND model/product numbers, since often the experts can check online to see how you can interface with these and configure them.
Posted on Nov 08, 2008
Anonymous
  • 69 Answers
SOURCE: linksys wireless G router not working when connected to dsl modem
hey there, can u acces the gateway of the router
192.168.1.1 than enter ur login & password
than reset the router to fabric setting when done go back in the router and configure it as u like to have it
Posted on Jan 04, 2009
How to connect to DG834PN
It's fairly straightforward. It connects to your WiFi as a wireless client. You can then connect wired network devices to it instead of needing to run a cable to the WiFi router.
Aug 09, 2014 | NetGear WNCE3001 Universal Dual Band...
Have a DIRECTV mobile internet stick, which plugs into a USB port to have internet access. I want to make my internet access a wifi access. What do I need to do this ?
If you do not already have a wifi router you will need to purchase one, install it and connect your Directv receiver to it. If you do have already, you will have to go through the settings on your Directv receiver to setup a wireless connection.
How to connect your DIRECTV Plus HD DVR to your home Wi Fi network with...
Jul 30, 2013 | Linksys Wireless-G WRT54G Router
My laptop works using my Belkin router, but my desktop will not connect to the internet
hello
your notebook has WiFi, which is radio frequency internet, it transmits and receives radio signals (frequencies) . Your desktop, most likely, does not support WiFi on its own , so you need to use RG45 cable , ethernet cable to be connected from your desktop to the router.
So in other words thsi is what happens with your notebook and the router.
  1. your notebook has built in wireless adapter which translates data into a radio signal and transmits it using an antenna.
  2. A wireless router receives the signal and decodes it. The router sends the information to the Internet using a physical, wired Ethernet connection, to your modem (supplied by your Internet Service Provider)
The process also works in reverse, with the router receiving information from the Internet, translating it into a radio signal and sending it to the computer's wireless adapter.
The radios used for WiFi communication are very similar to the radios used for walkie-talkies, cell phones and other devices.
you need to connect your desktop to the router via RG45 ethernet cable.
was this helpful ?
Nov 15, 2010 | Computers & Internet
We switched from cox Cable to Direct TV. The BD390 works normally through an Apple Airport Express with an Ethernet connection to a Motorola SB 6120 modem. The system does everything it is supposed to...
So practically you want to use the BR390 as an access point, to route the data from the Apple to the DVR. No, this isn't possible since the player doesn't have routing capabilities.
But you can do something else: instead of the Apple (which is just a very simple router with some minor extra capabilities sold ad an outrageous price) you could get a way better normal router for a lot less than $100 and connect all devices thru LAN cables in an local network.
Aug 17, 2010 | LG BD390 Blu-Ray Player
I brought new wireless router G ADSL2 4 PORT ROUTER but i dont know how to fix
Configure your router with below method then all messup will be fixed. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on WAn settings and set wan settings as internet service provider settings. Then click on wireless settings then enable wifi also enter SSID name and enable broad cast turn on wifi . If you want to secure wifi then enable WEP in wireless security .Enter code it is your password to connect wifi. Then connect internet cable to WAN port then you can use internet with it. Let me know if you need further assistance. Thanks for using FixYa.
Aug 04, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
HOW TO USE INTERNET IN MORE THAN ONE PC FROM LINKSYS WIRELESS G B
You have two ways on how you can get other computer online through this router. First, you can wired them (using an Ethernet cable) to one of the Ethernet ports on the back of the router. They are the ones labeled 1, 2, 3, and 4.
Second is through wireless, but those computers that will connect through wireless must also have a wireless adapter to be able to pick up the signal that this router is broadcasting.
Feb 12, 2010 | Linksys Wireless-G WRT54G Router
Can I use my router just as a Wireless router with a DSL .
i doubt it will work. most times the cable companies give you a modem/router all in one box. the problem is there in no inbound connection to recieve an internet signal other than the cable cord connection. with the dsl modem you will need a seperate router. they cost around $40-50 on avg
Feb 05, 2009 | Arris SURFboard SBG900 Wireless Router...
No wifi connection
Verify which MAC Address U have Cloned. MAC Address of Your PC WiFi and Cloned One must not be same otherwise it will not work...
Feb 02, 2008 | Belkin (F5D7231-4) Wireless Router
Jan 20, 2008 | Linksys Wireless-G WRT54G Router
u try to reset roughter unplug it back in after 20 sec do u have latest driver for your wifi in from lg or windows update custum scan im open for chat
Jan 07, 2008 | LG LW20-EV Notebook
Computers & Internet Logo
16 people viewed this question
Top LG Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
