I need to replace my blower motor on my air handler
Turn off power to machine and have a 5/16" or 1/4" nut driver handy take off front door of machine. Take a rubber coated Screw driver and place across the terminals of the Capacitor to discharge any stored electricity. Cut wires for blower Black, Red, white, two browns one with white lines on it probably. Look inside machine and locate where bracket holds squirrel cage to air handler and there you will find either 5/16" or 3/8" screw remove pull bracket out. Then you will need a 1/2" socket and a crescent wrench. Remove screws for motor bracket that is attached to squirrel cage. Also you need to loosen the set screw that attaches blower wheel to motor. Apply wd-40 if needed to remove blower wheel from motor. Then install new motor on the flat part of the shaft comes through wheel attach set screw to motor shaft at that position. Install new cap that goes with motor. place entire housing of motor back into air handler and then follow wires that where previously cut back to either relays, sequencers, or fan timer board located in top section of air handler. Tighten everything up and turn power on and make sure air is coming out of vents. Then your good to go.
