Vacuums Logo
Bob Tellis Posted on May 20, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to remove the dust cup on an Shark iondual2x
Cathann Smith
Level 2:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 42 Answers
  • Posted on May 24, 2019
Cathann Smith
Expert
Level 2:
New Friend:
Night Owl:
Answers
42
Questions
Helped
13084
Points
104
First, turn the power off and remove the battery. Then, separate the handheld from the rest of the vacuum by pressing the "Wand Release" button. Next, hold the dust cup over the trash and press the "Empty" button. Tap gently to empty contents and pull any debris off of the metal screen. If desired, wipe clean with a dry soft cloth. Close the lid. You will hear it click into place.
For optimal performance, the dust cup should be emptied each time you vacuum and when the dust cup appears full or debris reaches the "Max Fill" line.
1 Related Answer
txslim55
txslim55
  • 1104 Answers
  • Posted on Sep 13, 2015
SOURCE: How do I remove and clean dust cup?
https://www.youtube.com/redirect?q=http%3A%2F%2Fwww.crucialvacuum.com%2F&redir_token=nNVJWIsaOcPwxy4XXpEf6wnO5MZ8MTQ0MjI2MTQ3MkAxNDQyMTc1MDcy
2answers
I cannot empty my shark cordless vaccuum
Hi Joan,
I don't know what model number your vacuum is but I fount this short video that might help you.
Andrew
My Shark Navigator does not have any suction. The roller brush works. What should I do?
Hello, this is Ava with Think Crucial.
If the dust cup is too full, there is no space for the dirt to go when you are vacuuming. To fix this, remove the dust cup and empty the it.
If your vacuum is still not picking up dirt after emptying the dust cup, there may be something blocking the airway. There are two places where you can check for a blockage: the dust cup air duct and the intake opening behind the brush roll. To check for a blockage in the dust cup air duct stand the vacuum upright and remove the dust cup. Now you can disconnect the super stretch hose and check for clogs in the air duct behind the dust cup. If that is not the case, to check for a clog near the roller brush lay the vacuum down. Next check the opening behind the brush roll for clogs. If there is debris, clean the opening with scissors, carefully cutting away any debris.
Uncleaned filters may also the reason why your vacuum has lost suction. To clean the foam and felt filters, remove the dust cup and pull out the two filters that are on the top of the motor base. Rinse the filters with lukewarm water until the water is running clear. Let the filters dry fully before putting them back into the vacuum.
If your vacuum is still not picking up dirt, you may need to replace it.
Unfortunately, if none of the other solutions worked, your motor is going bad. Most of the time a new motor costs as much as the vacuum itself and it is not easy to replace the motor. It may be time for a new vacuum.
ou can purchase a wide variety of high quality Shark replacement parts for your Shark vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=shark+navigator
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
1helpful
Shark navigator lift away turns on but no suction
It seems that there may be something blocking the airway. To fix this, please make sure to unplugged the unit from the power before performing this.
If the dust cup is too full, there is no space for the dirt to go when you are vacuuming. To fix this, remove the dust cup and empty the it. If your vacuum is still not picking up dirt after emptying the dust cup, keep reading for other options to fix the suction.
If both your foam filter and felt filter have not been cleaned in the past month, this may be why your vacuum has lost suction. To clean the foam and felt filters, remove the dust cup and pull out the two filters that are on the top of the motor base. Rinse the filters with lukewarm water until the water is running clear. Let the filters dry fully before putting them back into the vacuum. If your vacuum is still not picking up dirt, you may need to replace it.
If none of the other solutions worked, your motor may be bad. You would need to check with Shark about this.
If your need to replace your Shark parts such as filter, belts or hose, you can also order replacement parts directly to us. You can check our online store in this link: http://www.thinkcrucial.com/search?type=product&q=shark
As a special offer here is an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Ava B.
Shark rotator no suction
You can purchase a wide variety of high quality Shark replacement parts for your Shark vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=shark+rotator
Ava B.
How do i unclog shark navigator when dust won't go into cup?
Hi, it's Allie from Crucial Vacuum.
Loss of suction into the dust cup may be caused by either the dust cup filters or the motorized brush.
After unplugging your unit, press the release button on the back of of the unit and remove the roller brush. To make sure there is no blockage in the air hose, flip back your unit and remove any debris clogged inside the hose. With a pair of scissors, carefully cut any hair strands or debris tangled in the roller brush. Make sure you do not cut or damage the bristles. Make sure there is no clog inside the air duct at the bottom of the unit. Re-install the brushroll by clicking it into place. If the problem still persists, you may need to check your unit's filters.
Check you filters by first removing the dust cup and then removing the foam filter and rise under lukewarm water until the water runs clean. Do not use soap. Squeeze the excess water off the filter and allow it to air dry for 24 hours before use. Washable filters are recommended to be washed after every 2 to 4 uses and replaced every 3 to 6 months.
You can purchase direct your replacement filter from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Alejandra (Allie) Sepulveda-Rivera
Crucial Vacuum Customer Care
Where do you get filters for a EP366
TO ORDER REPLACEMENT DUST CUP FILTERS
To order, send check, money order or credit card authorization to:
EURO-PRO Operating LLC
94 Main Mill Street, Door 16
Plattsburgh, NY 12901
or call
EURO-PROCustomer Service at: 1 (800) 798-7398
Monday to Friday 8:30 A.M. -5:00 P.M. Eastern Standard Tim
Please Note:
The Shark Dust Cup Filters are washable.
Importan
Make sure that Dust Cup Filter is completely dry before inserting back in the hand vacuum
http://www.sharkclean.com/manual/EP366_(700_WATTS)_REV_0603A.pdf
My Shark vacuum is losing suction. How do I fix that?
If the dust cup is too full, there is no space for the dirt to go when you are vacuuming. To fix this, remove the dust cup and empty the it. If your vacuum is still not picking up dirt after emptying the dust cup, there may be something blocking the airway. There are two places where you can check for a blockage: the dust cup air duct and the intake opening behind the brush roll. To check for a blockage in the dust cup air duct stand the vacuum upright and remove the dust cup. Now you can disconnect the super stretch hose and check for clogs in the air duct behind the dust cup. If that is not the case, to check for a clog near the roller brush lay the vacuum down. Next check the opening behind the brush roll for clogs. If there is debris, clean the opening with scissors, carefully cutting away any debris.
Uncleaned filters may also the reason why your vacuum has lost suction. To clean the foam and felt filters, remove the dust cup and pull out the two filters that are on the top of the motor base. Rinse the filters with lukewarm water until the water is running clear. Let the filters dry fully before putting them back into the vacuum. If your vacuum is still not picking up dirt, you may need to replace it.
You can purchase a wide variety of high quality Shark replacement parts for your Shark Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Ava B.
My vacuum (shark modle #UV210BV) turns on but has absolutely no suction.
If the dust cup is too full, there is no space for the dirt to go when you are vacuuming. To fix this, remove the dust cup and empty it. If your vacuum is still not picking up dirt after emptying the dust cup, there may be something blocking the airway. There are two places where you can check for a blockage: the dust cup air duct and the intake opening behind the brush roll. To check for a blockage in the dust cup air duct stand the vacuum upright and remove the dust cup. Now you can disconnect the super stretch hose and check for clogs in the air duct behind the dust cup. If that is not the case, to check for a clog near the roller brush lay the vacuum down. Next check the opening behind the brush roll for clogs. If there is debris, clean the opening with scissors, carefully cutting away any debris.
You can purchase a wide variety of high-quality Shark replacement parts for your Shark vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Ava B.
Top Shark Vacuums Experts
vince
Paul Carew
Are you a Shark Vacuum Expert? Answer questions, earn points and help others
