Check battery and charging system. Battery voltage should be >14 volts with engine running, >12.5 volts with engine off.
Testimonial: "Charging system is fine and brand new battery, it restarts after 5 or so minutes"
This has RIO with several safety interlock switches and relays. You'll need to isolate each individually or bypass to find root cause. Could be the clutch or a connection (pin/socket) to the clutch is failing so check voltage at the clutch leads or jump to battery to isolate.
Thank you very much
SOURCE: adjusting John deere ''Sabre'' model deck
Move machine to flat/level surface,with deck raised put a 2x4 between rear of deck and ground.Make sure that the 2x4 goes all the way under deck from one side too the other.Once that is done lower deck all the way and make sure lift lever is all the way forward.Then on the rear top side of deck loosen bolt that holds arm to deck bracket,pull bracket as far down as you can then retighten bolt.This is also the point where you can level deck side to side.
SOURCE: I have a John Deere X304 that mows unevenly.
Make sure that your gauge wheels are not running on the ground during mowing,they should only hit the ground when you engage a high spot on one side.also when you level the deck the front should be a 1/2" lower than the rear.
SOURCE: How to install John deere lx255 42c mowing deck
How to install John deere lx255 42c mowing deck blade belt
SOURCE: i need to run the mower deck belt on my john deere...
I have to replace my broken belt on my L110 John Deere mower. I have the new belt in my hand...
SOURCE: John Deere x300 runs for about 30 minutes then stalls. There is no gas in the filter.
Check your fuel cap to make sure it is venting properly. If a vacuum is being created, and no air is able to get into the fuel tank, it will prevent the fuel from reaching the carburetor.
It will cut for about 20-30 minutes then stop but engine keeps running
