SOURCE: I can't get my 2007 virago 250 to start.
It sounds like you have a plugged jet or needle in your carb. It will start with a spray, and turning it over sends fuel out of the line means the fuel pump is working. Go over the main jet, needle jet and float needle closely, not to miss any small openings that may be plugged.
SOURCE: fuel leaking out of air intake
hello, you may need to check float in carb, could be sticking or bad, make sure plugs aren wet with gas insted of oil, you can smell gas fouled plugs, than oil, gas coming out of breather sounds like float needs to be adjusted or floats bad or trash in carb, may have broke ring also
SOURCE: is their some way to
this link will tell you everything you need to know about your bike plus more
http://www.kawasakipartshouse.com/?gclid=CJKezo-w7acCFQRMgwodABTCZw#/Kawasaki/ZX1000-A2_Ninja_1000R_%281987%29/CARBURETOR_ASSY
SOURCE: I replaced gas tank, fuel
A mechanical fuel pump works off a lobe on the cam, usually. I have seen these cams wear down to the point that the fuel pump does not operate correctly. A quick test is to; remove the fuel lines from the pump, plug the oulet side of the pump with your finger, install a vacumm gauge on the inlet side and crank the engine. The gauge should show good vacumm and you should feel pressure against your finger. If none of these exist then you should replace the camshaft.
Check/change fuel filter. Bleed fuel line. Be sure shutoff valve is wide open. .
