SOURCE: Why would my sst18 john deere zero turn steer in
there is a servo under the main body on the right side win sitting in seat thats broken from [email protected]
SOURCE: My sons john deere gator started going forward in
It sound to me that you have put the battery on the wrong way round.
Check that it is connected the correctly.
Regards
Alan Hood
ami-man
SOURCE: I have a John Deere
probably a bad shifter switch you can order a new one here www.powerwheelsoutlet.com
SOURCE: John deere sabre 2354 hv moves slow forward, even slower in reverse
this hydrostat drive tractor is designed to max at 5.5 mph forward, 2.5 in reverse, check linkage at pedal if you dont think your achieving those speeds
SOURCE: why does my john deere d130 rev up then down and wont cut do lack of power
This is called "surgung" or some people say "hunting". The carburetor needs to be serviced. Basically, you may have clogged ports or the tiny holes that disperse the fuel to the sections of the carburetor are clogged... so when your engine demands more fuel and oxygen it's not getting the proper ratio.
Visit you tube and search how to clean/ service a 4 cycle carburetor
