Question about Kenmore Microwave Ovens
I need to remove the control panel on a kenmore mod 790.80379210 microwave.
2 Suggested Answers
6ya staff
SOURCE:
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: I need to replace the
1. Unplug the microwave or turn off its breaker.
2. Open the door, then detach the control panel as shown in the video at
http://www.microwavedisplay.com and swing it down, but without disconnecting the wires.
If you have any trouble getting the grille off once the screws are removed, slide the hood vent grille to the left about 1/4", then then pull it forward.
On some models there are L-shaped clips that fit into a slot to hold bottom of the vent.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
They're our favorite supplier.
Posted on Aug 23, 2010
My Kenmore microwave says LOCK on the display. How do I unlock it?
  1. Touch and hold the "Enter/Start," "Start," "Lock" or "Control Lock" key, or key that has a padlock image, on your Kenmore microwave's control panel for about five seconds.
  2. Check that the word "Locked" has disappeared from the display.
More items...
How to Unlock a Kenmore Microwave ' Hunker
https://www.hunker.com/13408005/how-to-unlock-a-kenmore-microwave
Kenmore microwave says LOCK on the display How do unlock it Google Search
Mar 12, 2018 | Kenmore Microwave Ovens
Remove panel
Unplug microwave, remove top, "several screws" you will see the control board mounted behind keypad, you should see insert screws where the top of the microwave was, there may be one or more so take your time. If you end up disconnecting wires make sure you know where they go, gently remove frame and leave the microwave door open so no latches get broken.
Apr 02, 2012 | Kenmore Microwave Ovens
Microwave oven kenmore 401.80086700 need to know how to acess the fuse in it
If this an over the range microwave, there should be a couple screws on the door side of the control panel that you remove and the control panel will drop down so you can access the inside of the microwave.
Jun 20, 2010 | Kenmore 62702 Microwave Oven
Kenmore Elite Microwave Oven (mod 565.61589011). No power or display suddenly. Circuit OK and no traumatic episode to suggest cause.
usually it is the fuse that blows out.if u remove control panel u cna see 20 amf fuse behind if.chk for continuity.if open replace it. it also could be the cavity thermal cut off must have blown out if cooking is done 4 long period.it is mounted on top of cavity. similar way as fuse chk 4 continuity.if open replace it
Aug 13, 2009 | Kenmore Microwave Ovens
After use, fan keeps running and control panel not working
Hi, this is a major chip fault. this chip is located on the control board and, it is responsible for initiating the cooking cycle correctly. you will need to replace the control board asap. it has failed.
Jun 19, 2009 | Kenmore Microwave Ovens
F9 code on mod 721-80869400 kenmore elite
This is usually inverter trouble, but it may be the magnetron, controller, wiring, etc.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
To find helpful exploded view diagrams and get part numbers, you can just enter your full model number at the Sears parts site.
May 17, 2009 | Kenmore 63792 Microwave Oven
Kenmore Mod. 721.80524500 microwave door will not lock.
If you gently push up on the door latch heads (hook-like devices sticking out of the door) there should be spring tension. If they just flop right up, the spring is off inside.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Mar 06, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
Where is the capacitor located in the Kenmore Elite?
It depends on the model. It's usually behind the grille or control panel.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our site, we have a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Nov 01, 2008 | Kenmore 62622 Microwave Oven
Possible fuse blown
That would be located behind the control panel.
In essence, you unplug the oven, remove the grille from across the front, then you'll see the screw holding the control panel on.
Once that screw is removed, the control panel can be lifted up and out, then you should see the fuse.
You can probably find an exploded view by entering your FULL model number here: http://www.searspartsdirect.com
A full Sears/Kenmore model number usually has 3 digits, a dot, then 8 more digits, such as ###.########
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 11, 2008 | Microwave Ovens
Microwave Ovens Logo
133 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
