Question about Shark Vacuums
My shark cordless duo when turn off bits of previous dirt particles fall out onto floor
5 Suggested Answers
advacak
Denny Adams
  • 125 Answers
SOURCE: my hoover vacuum spits out dirt particles as I vacuum!
the vacuum is clogged somewhere the brush roller is just kicking stuff around, as it cant get into the suction port
Posted on Dec 02, 2008
Anonymous
  • 134 Answers
SOURCE: throws dirt back out
High, its blocked up. Check by the brush and all hoses
Posted on Mar 12, 2009
vetteman3002
Rodney Clark
  • 2299 Answers
SOURCE: My shark cordless vac 15.6V
Either one of two things can be wrong. 1st and most common problem is the filter is clogged up, or too much dirt in the containment reservoir. The second problem is the belt is broke that turns the brush.
Posted on Oct 09, 2010
geterrollin
Tyler
  • 277 Answers
SOURCE: when I vacuum the floor
blockage in the hose sounds like the culprit remove the hose and inspect, push a broom stick through it while off and push a open coat hanger through the canal where the hose connects, if not the filter must be blocked
Posted on Jan 18, 2011
Paul Bade
  • 1662 Answers
SOURCE: My Kirby seems to be
Do you have suction? If the bag does not inflate when you turn on the vacuum cleaner, you do not. If you aren't sure, remove the belt from the roller and test whether the vacuum cleaner can pull in a strip of tissue paper. If not, look for clogs or a problem with the blower. An overfilled bag could also cause this problem.
If you have recently had the motor brushes replaced and you have air blowing out (the bag may collapse instead of inflate when you turn it on), then the wires to the motor brushes are crossed and the motor is running backwards. You will also see the brush turning the wrong way (back to front on the bottom instead of front to back).
Posted on Feb 09, 2011
How to fit small car bits to shark duo clean hoover
Can you be a bit more specific as Shark & Hoover are 2 different vacuum manufacturers. Shark is part of Ninja products and Hoover is a brand on its own! What small car bits are you referring to. As my best knowledge the only car detailing pieces that will work with either of those 2 vacuums are the ones they make and sell if they do. Some brands may not offer the detailing car kit! When I bought my Shark I got the pet care package and the car detailing kit! Those are some quite small pieces!
Jun 23, 2018 | Hoover Vacuums
Panasonic Dirt Sensor vacuum repair
Dirt Sensors are sensitive. It doesn't take much to set them off. Try pulling back on the handle to raise the brushroll a few inches off the floor so you know it's not detecting particles of soil. If the light doesn't turn green it may have dirt on the sensors and need to be cleaned.
Nov 25, 2017 | Panasonic Vacuums
Why won't shark cordless stick vac motorized brush work?
Is the brush rotating, if not the belt is broken or jammed, if so remove the bottom plate and all will be reveiled.
Oct 17, 2014 | Euro-Pro Shark Cordless Stick Vacuum...
Green light on comes on when the vacuum is off the ground
It's supposed to do that. There's a small, very sensitive microphone in the elbow of the dirt passage coming off the back of the machine. As long as it's in contact with a dirty floor, the smallest piece of dirt going up through the hose will turn the light to red. Once all the dirt particles have been passed through, it turns back to green.
Oct 23, 2013 | Kirby G6 Bagged Upright Vacuum
Shark SV736R motorized brush won't rotate
The 2 metal pins of the motorized brush are not in contact with the vacuum cleaner. or the Motorized brush is clogged up. You have mentioned that it is cleaned, but still give a thorough inspection. For the metal pins, firmly insert the motorized brush into the air-intake nozzle. This will connect the motorized nozzle to the unit power supply.
Oct 21, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Engonmic hand grip broke off
Check the manuals link and maybe they will replace it under warranty...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Aug 24, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My hoover vacuum spits out dirt particles as I vacuum!
Aug 25, 2008 | Hoover S3614 Vacuum
Vacuums Logo
54 people viewed this question
Top Shark Vacuums Experts
brian kossman
Level 1 Expert
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Shark Vacuum Expert? Answer questions, earn points and help others
