SOURCE: after each shot the nail gun jams
hi visit your supplier and ask for a overhaul kit once fitted your tool will be licke new
best of look ian
SOURCE: Senco narrow crown Stapler Piston will not go back
There is a spring and piston in the back cap of the nailer, this must be free moving and not sticking. If it is sticking it will cause the problem you discribed. If that looks ok you probably should install an o-ring kit and that should solve the problem. A Senco service center will carry the proper parts.
SOURCE: (DP) air staple gun won't reload after shooting 1 staple
i have mini blow 8 mm gun automatic after i chut he did not reloaded plz tell how i can fixed
SOURCE: paslode impulse cordless nail gun,doesn't pull the
This is an easy fix luckily usually it means that the chamber is dirty and all you have to do is open the top front of the gun so that you can see the piston then take a q-tip and clean the area really well sometimes it requires a degreaser and then when you think that you have it clean make sure to lubricate the chamber really well with the paslode lubricant that came with the gun or they sell it right next to where you get the nails. Then the gun should work fine with no problem if this does not work then this means that the piston might be bent and that could turn into a big problem but is still fixable just harder.
Hope that this works for you
Testimonial: "Thanks very much for your help,I took the piston out and sprayed it all out with solvent and relubed everything and it seems to work fine."
