Canon PowerShot G9 Digital Camera Logo
Posted on Aug 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Video records at high speed
When I record a video and play it back on the camera, it plays back at a high speed,like it's on fast forward. What's up?
  • budstockwell Aug 10, 2009
    The way I fixed it was that I needed to be in video mode first. Then I was able to turn the dial and get to the settings area. I just couldn't find that place at first. Thanks for the help.
picaday
Level 2:
  • Expert 80 Answers
  • Posted on Aug 28, 2009
 picaday
Expert
Level 2:
Answers
80
Questions
0
Helped
77743
Points
227
You need to change your video settings. You have it set for time lapse. Turn your camera to the video mode on the top of the camera and then turn the dial on the back of the camera to the size of video you desire.
2answers
I have a Panasonic omnimovie Pv-610 and only one of my vhs tapes plays in fast forward mode, how can I fix?
If you mean just the one and the rest then it was probably recorded in Extended Play mode and nothing can be done.
Otherwise please explain your issues in more detail.
Cant playback tape
Videos recorded on one camcorder very seldom play back in another, due to the internal codes put on the tape by the original machine.
1helpful
Canon ixus 75
Unfortunately, no. By recording in fast mode, the camera captured fewer frames than usual. When played back at the normal speed, the action appears faster than normal. Because the camera recorded fewer frames, there is no way to make up for the images that were not captured. You could slow down the playback, but the result would be a jerky, jumpy video.
Now, if you had accidentally captured the video in slow motion, you could then throw away some of the intervening frames and recreate a normal-speed video.
Tape is playing back in fast forward only
It is possible the tape loaded on the wrong side of the drive. If you romove the tape, look for slack and tighten up, try it again or another tape. Otherwise it is likely that a spring for the pressure roller is off or broken. This is not easially repairable.
1helpful
2answers
My g9 was playing video clips very fast. i changed the setting back to "standard" and can record/play new videos correctly; however, the video clip that i previously recorded before i changed the setting...
I believe the setting you changed set the RECORD method, not playback. The video is recorded that way. There are some Video software out there that can rerecord a video at a slower pace, but do you want to spend the money? Try Ulead.com for a low cost program.
35helpful
Video playing in fast forward with no sound
This is a really simple problem and easy to solve.  Unfortunately the videos you've recorded cannot be changed back because they have been recorded in Time Lapse mode.
With the camera switched on in Video Mode turn the control dial on the back (this is the dial to the right of the LCD screen).  This will change the settings from TIME LAPSE to STANDARD.  There are actually 6 different modes but the best one for normal videos is STANDARD.  There is a HIGH RESOLUTION setting,  however these record fewer frames per second (fps) so whilst the quality is better per frame,  there are half the amount of fps so the the movie will look at bit jerky.
It's really easy to accidentally twist the dial when holding the camera,  so always check the icon in the top right of the LCD before recording to make sure its just a yellow camera in a yellow square.
This should be problem solved for all future recording.
Camera plays in fast forward-like speed
Though I don't know the details of your camera and the tape you are playing, one explanation could be that the tape was recorded in "extended play" EP rather than "standard play" SP. Some VCRs and some cameras are incapable of playing back in EP, a mode where the tape moves at half speed so you can record more on the same tape. The result is that the tape playing back at regular speed appears twice as fast and fast forward will be even faster.
Unfortunately, unless your machine can be manually set to play back in EP (usually it is automatic) the solution is to play it back in a machine that can handle EP.
3helpful
3answers
I have a canon SD 580. When I playback the video clip it's always in fast forward mode and I can't play it normal speed. Any help?
Make sure you are shooting your movies in "Standard" mode. If you have the mode set to something else, especially "Time Lapse", the playback may not match 'natural' motion.
In any case, you can control the speed of the playback. When you first enter the movie playback mode, there should be a movie control bar along the bottom of the LCD. Instead of the "Play" button, select the "Slow Motion Playback" button (single arrow with single bar next to the normal Play button), and control the speed with the left or right arrows on the multi-controller.
May 02, 2008 • Cameras
Sony Handycam CCD-FX310
Record in slow mo mode, then playback in fast forward mode ;) Problem solved. You'll see the video in normal speed.
Help it's going to fast
Your camera has a capstan servo problem which is more than likely being caused by the capstan motor itself.Nothing you can do youself,would suggest bring to service but reccomend getting estimate before repairing.
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
