SOURCE: color schemes other than default
guys you can go to the modmymoto.com and register yourself over there and than overe there lot of themes are avilable you will like it ...i have updated my rockr e6 too...hope you will enjoy.
thanks and regards
siddharth
SOURCE: When turning on the Lowrance
here is the link to your the lowrance web site. the trouble shooting guide says that if you tried to it on another boat than you might need to take it in for service. but there is a section that explains how to do a soft reset on the unit. you might try that.
http://www.lowrance.com/en/Support/Troubleshooting-Guide/Depth-Reading/
please rate and comment on your experiance with fixya.
SOURCE: installing an old used lowrance fish finder
I don't think your old fish finder is the LMS-332C GPS Receiver listed above in the description. You don't need the speed wheel for the fish finder to function just the transducer and transducer mount. You should mount that on the back of the boat towards the center but not too close to the motor and not too close to the side of the board. Don't let it hand below the level of the boat. That should keep it from getting hit by the trailer or dragging on the bottom. Try to make it as level as possible. The green and white wires may be for the speed wheel but i'd need a model number for clarification. Hope this helps.
SOURCE: lowrance depth finder missing adapter cable
I own a 1995 Four Winns and what you need is a Lowrance LSM-1 depth
finder unit. It accepts the two pin lead from the transducer and send
the depth reading to the dashboard display via the 6-pin connector.
There is also a three wire harness (red/blk/wht) that connects to a
power supply.
The reason I know all this is my depth finder
fried a couple years ago so I removed the Lowrance LSM-1 from the boat
in order to find a replacement. Unfortunately, this was an OEM part
that is not available from Four Winns or any aftermarket source.
Probably your best bet is to look in a boat salvage yard or purchase an
aftermarket depth finder.
SOURCE: my fishfinder lowrance x85 the
It is not the transducer. the transducer just provides the sonar reading back to the display. The issue is with the display head unit. Have you tried to adjust the contrast for the fading? Does the screen disappear after awhile? Is the head unit mounted close to other navigation equipment, such as a Compass that may cause interference?
